Injectors size?!?
I wonder with size injectors i need to run on my motor. Here is a quick break down of what i'm running
*f22b1 motor (fully build)
*NX direct port (100shot)
*F-max turbo (TO4B)
I just ordered 370, but someone told me i need to run higher, just wonder what u people think?
thanks
*F-max turbo (TO4B)
thanks
actually since a wet nitrous kit doesn't require any more from the injectors...your just running the turbo on a F22...and the f-max has its own secondary injectors...so really...theoretically you don't even need them.
Fuel mods includes: Hytertech fuel pump, upgraded rails, and thats about it, unless u have any other suggestions.
I wanted to built the motor to handle 15psi daily driven, but I was unable to get block guards for my motor in time, while they were building it. So since i couldn't get my guards in, i can only run about 13psi.......(15 w/race fuel)
any pictures of it? I can host them if you like.
wow, 13 psi sounds like a lot...but I guess 8.8:1 compression is a dream come true with turbo...
wait, since you're built it, did you change the compression?
Yes, i acutally got some of my pictuces from the machine shop today
Let my know how?
Let my know how?
[Modified by 01GSR, 1:00 AM 4/17/2002]
550 cc/min
is you fuel system still stock?
if you have just a fuel pump and fuel rail I highyl reccomend you do an inline high flow fuel filter with an-6 hose and replace the stock hardline with a larger one to accomidate the an-6 size, as banjo bolts are great for keeping pressure in the system consistent but are shitty flow wise
may i ask what kinda engine management are u using to control your fuel and timing
and 370cc are to small
i run 450cc
and what kinda fuel psi to
i run 450cc
The reason why i went with 370 is because i haven't got my stand alone yet. Still trying to figure out which one to go with. "do j00 have a quaife oO?" NOPE.
Because that was the smallest jets i had from my NX direct port Kit. Plus im only spraying from 2000 to 3200 rpms. Well my tranny is the weakest part of my setup, but i have 2 trannys to play with until the summer when i get my tranny built by level ten....... I would of did it sooner, but they wanted to charge me $4500.00 to do it.......
Why a 100 shot? Why not just a 25 or so to get the turbo spooled up faster?
That F22 + Tranny better be superdeeduper strong
your running an auto tranny?
uhhhh oooooohhhh
level ten has the fully built honda tranny listed for $2500 on their site...
like i said...with the fmax kit and a direct port...you really don't need higher rate primary injectors...
once you get a standalone, ditch the fmax auxillary injectors, run a dry shot, and run some 550's or so...
uhhhh oooooohhhh
cool thankx, my car should be up and running sooon. I have finals right now and and whole bunch of papers to write. Haven't got a chance to bolt my axles back on yet
cool i just when to level ten web site...... your right on the tranny..... i wonder why when i called them a few months early the price was 4500???? owell who cares. I guess im going to call them up on monday to see how soon they can get me one...
thanks for u info
[Modified by NXAccordTO4B, 6:16 AM 4/20/2002]
thanks for u info
89si-rex
19
Dec 20, 2013 03:12 AM
