how long does an oil pump last and how can you tell if it's going out?
Old Apr 16, 2002 | 09:12 PM
Lei Siew Long's Avatar
Default how long does an oil pump last and how can you tell if it's going out?
i'm thinking about upgrading to a VTEC oil pump but i would like to know the life expectancy of an oil pump first before i shell out the money for the pump.
Old Apr 16, 2002 | 10:03 PM
VaporTrail's Avatar
New User
Default Re: how long does an oil pump last and how can you tell if it's going out? (boostedeg6)
its a wear and tear item. The more stress you put on your motor (via power, driving style, and method of delivery), the more stressed your oil pump becomes. Drive it like a saint, it'll last the life of the motor. Rev it/boost it to high hell, it'll explode in spectacular fashion. They don't go with warning - usually, they just seize or shatter, and you lose oil pressure, and if you're not quick, you'll spin a bearing or even throw a rod.
Old Apr 16, 2002 | 11:46 PM
sparkz's Avatar
Just purchase a new oil pump from the dealer. Should be under $100 and well worth it
Old Apr 17, 2002 | 08:54 PM
Default Re: how long does an oil pump last and how can you tell if it's going out? (VaporTrail)
thanks for the info vaportrail. btw, how's your car coming along?
garagespecial
Apr 26, 2003 01:16 AM
