I did a bad bad thing
SHORT STORY:
I grounded a hot wire while the motor was running. Now the car will not start.
LONG STORY:
My CEL came on for IACV. I cleaned it and put it back. Still thru a CEL. Tried a new IACV. Still thru a CEL. Decided to check the current. Started car went to check and ground one of the wires. Car died and would not start back up. CEL just stays lit. I tried to reset the ECU but the CEL is still staying on and the car will not start.
Did I ruin the ECU or is there something I am not thinking of?
LONG STORY:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkspector »</TD></TR><TR><TD CLASS="quote">check your coil and or your ICM</TD></TR></TABLE>
I would second this opinion. Do a current test to see if your icm is bad. http://autorepair.about.com/li...b.htm
I used that to check mine. Click on the testing honda ignitors link.
Max
Max
I will look at it before I bother to *cough*steal*cough* my friends ECU. This might be the right time for a P28/hondata. I woln't be able to check it out untill I get home from work.
Is the CEL not flashing a code for you? If so, that means that you aren't getting power to your ECU. Check all of your fuses, check the main relay, and try a different dizzy (ignitor might have fried?).
i grounded out my alternater wiring before and another wire(wasnt sure which one) but anyways every time it poped the batter fuse...thats the firtst thing i would check. 70a fuse. under the hood.
tpeter91
Oct 25, 2010 06:33 PM
