speedometer and odometer wiring?
Old Jun 18, 2006 | 10:33 PM
sir2sol's Avatar
Default speedometer and odometer wiring?
i was planning on rewiring my vss (due to the fact that i'm pretty sure the wiring's messed up). i've got a 94 del sol with a b16a swap and was wondering if anyone has tackled this task before? i know that there are 3 wires (ground, power and a wiring that goes to the ecu, but do you wire it up just like that? any info on this would definitely be appreciated.
Old Jun 19, 2006 | 07:40 AM
sir2sol's Avatar
Default Re: speedometer and odometer wiring? (sir2sol)
bump
Old Jun 19, 2006 | 07:07 PM
sir2sol's Avatar
i know someone else has done this
Old Jun 19, 2006 | 07:41 PM
B16CRXT's Avatar
I have a similar problem...aparently nobody has any idea...
https://honda-tech.com/zerothread/1662406
Old Jun 20, 2006 | 01:41 PM
sir2sol's Avatar
Default Re: speedometer and odometer wiring? (B16CRXT)
is there a relay for the vss? i hooked up 3 wires (power, ground and source) and still nothing. i know the problem's not my vss, not my gauge clauster, not my ecu and now not the wiring. what else could it be? if it was just a problem with my clauster, then it wouldn't throw a cel code, correct? need to fix this problem, it sucks having a b16a and not being able to have the advantage of vtec due to the fact of running in "limp" mode cause of a cel.
Old Jun 20, 2006 | 03:11 PM
B16CRXT's Avatar
All I really know to tell you is; the power wire goes to a switched power source and the signal wire goes to the ecu AND a wire (VSS or speedo) on the cluster.
Old Jun 21, 2006 | 10:01 PM
sir2sol's Avatar
ttt
existanzcivicb20
Dec 25, 2013 03:41 AM
ericrcan
Feb 29, 2012 04:30 PM
boosted98acura
Jan 27, 2008 02:56 PM
APEX CRX
Aug 11, 2005 09:18 AM
triceeetrev
Sep 10, 2003 01:13 PM
