what kind of LCA's are you guys running?
Old Jun 18, 2006 | 09:34 PM
EF9 JAMS!!!'s Avatar
Default what kind of LCA's are you guys running?
as topics says
Old Jun 18, 2006 | 09:46 PM
Default Re: what kind of LCA's are you guys running? (aallbbeerrtttttt)
okay how about this what LCA's will work with a stock si sway bar?
Old Jun 18, 2006 | 10:06 PM
Jonknee's Avatar
Default Re: what kind of LCA's are you guys running? (hatch91JDM)
Do aftermarket lca's make a noticeable difference compared to stock.
Old Jun 18, 2006 | 11:17 PM
user 98292739's Avatar
i run the Function/Form LCA with my stock Si sway bar
Old Jun 19, 2006 | 07:38 AM
QuarterMileMaster's Avatar
Default Re: (The Lobster)
1998 ITR LCA's with ST 22mm Sway Bar
Old Jun 19, 2006 | 07:55 AM
ludesrv's Avatar
Rock it like it's stock...
I rock 90 Civic Cx LCA's and they are the ****. They have a stock sway bar too.
You don't really need to upgrade really unless you ran out of stuff to do and you want some bling. Honda makes a pretty strudy LCA, just get new bushings and you will feel the difference.
Old Jun 19, 2006 | 07:56 AM
CRX Toad's Avatar
Default Re: what kind of LCA's are you guys running? (La-quiete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by La-quiete &raquo;</TD></TR><TR><TD CLASS="quote">Do aftermarket lca's make a noticeable difference compared to stock.</TD></TR></TABLE>
No they don't.
Stock LCA's on every CRX I own. DrDisco69 has stock LCA's on both of his CRX's too.
Old Jun 19, 2006 | 09:03 AM
rsca_crx's Avatar
sure they do, as long as you hit the pothole/curb hard enough...
i'd run them only on a dedicated autox car where they were legal, and you'd already finished building the rest of the car and had exhausted other less expensive/ more effecteve methods of weight loss. and when a company releases a version that accepts spherical bearings.
for a dd they are lots of money for something that you won't notice, and might break. for a car that sees track time or a club racer, the material properties of steel vs. aluminum would make me want to keep the 2 lbs for a little added security.
i don't build or have any interest in show cars, and i won't degrade the conversation and the product by entering them into the conversation.
Old Jun 19, 2006 | 10:38 AM
mike-y's Avatar
Default Re: what kind of LCA's are you guys running? (rsca_crx)
well said.
I run 95 integra rear LCAs on my 89. I got them with anticipation of running a rear swaybar, but then I found out you don't need LCAs with swaybar holes to run the ST
bar.
Old Jun 19, 2006 | 10:48 AM
will the (DA) integra lca's work? does it matter what year?
3rdtimecharmer
Mar 22, 2014 02:18 PM
Jimmy
Suspension & Brakes
Nov 26, 2010 03:09 AM
20ls01
Feb 20, 2007 02:06 PM
SiZ
Jun 4, 2006 12:44 PM
01-0041
18
Jan 1, 2004 08:04 PM
