How Wide are your Wheels?
So i'm thinking of running 17x9 +35MM offsett wheels.. on my 4dr integra.
I know i gotta do a few things to make them fit.
Slamm the **** out of my car, run lots of negative camber, and roll the hell out of my fenders.
Anyone else run something agressive like this?
Post up comments / suggestions etc.
Thanks!
Thanks!
no, 9's are too much rotational mass and uneeded traction, i doubt your gonna find too many people runnin 9's unless they have a staggered setup 9 up 7-8's in the back.
8's are perfect for the big and beefy look they look quite large on honda's, not to mention mad traction and still willl handle well
perfect for 300+whp
7.5 on my ek
9's up 10's back on my 240
perfect for 300+whp
7.5 on my ek
what do u mean to little power? we just got done building a 500whp 2.2l eagle stroker b-series motor with aem ems and a blowzilla turbo from turbonetics.
our customer is sitting on 7.5in buddy clubs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlamminS85 »</TD></TR><TR><TD CLASS="quote">hmmm do something funny, put on 4 spare donuts and see how fast you can rip through them</TD></TR></TABLE>
um okay thanks anyways.
FIRST decide what size tire you want. THEN find out how wide a wheel it will accept.
On most Integras, if you get 17" wheels, you want to get 205/40-17 tires. Because they have the same outer diameter as the stock tires, they shouldn't rub and they won't make your car accelerate slower like larger tires will.
Most 205/40-17 tires are approved only for use on rims that are 7.0-8.0 inches wide. I would suggest getting 17x7.5 because, at the high end of the range (17x8), the tires may look a bit "stretched", and at the low end (17x7) they may look "bulging".
205/40-17 on 17x7.5
205/40-17 on 17x7.5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">FIRST decide what size tire you want. THEN find out how wide a wheel it will accept.
205/40-17 on 17x7.5
thats what i was going for. the stretch tire look. The reason why i want 17x9 is because i wanna run the rim with a 3" lip all around.
I'm not sure if you ever seen a honda running RWD offset rims, it looks hella dope if done correctly.
205/40-17 on 17x7.5
slamming the car is not part of the solution to not rubbing, even though it looks better that way than sitting high up.
My buddy ran 245/35 tires on 19x9 wheels on his Audi A4 and they were CRAZY f'n huge. much much much too big for a Honda.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">thats what i was going for. the stretch tire look.</TD></TR></TABLE>
Then get 17x8.
Then get 17x8.
Then get 17x8.
the rim only comes in a 17x9 with a 3" lip.
Then get 17x8.
the rim only comes in a 17x9 with a 3" lip.</TD></TR></TABLE>
Good luck with that. Run a 7.5" wide wheel at the most.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutupnskate »</TD></TR><TR><TD CLASS="quote">Good luck with that. Run a 7.5" wide wheel at the most.</TD></TR></TABLE>
I try to think outside of the box.
