do i buy spark plugs clutch etc. from a 99-00 civic for my b16?
heres the deal my boy just purchased a b16 from hmotors and before we install it we wanted to give it a complete tuneup. change all the gaskets we also wanted to put a new clutch and flywheel but they say its for a 99-00 civic si. would the parts fit?
for spark plugs you can get 99-00si or delsol vtec b16a3,,,,make sure to repeat yourself 20 times when you order,,ive gotten numerous parts for sohc instead of dohc plenty of times cause they're idiots..
for clutch it depends,,im assuming your friend order the obd0 b16 swap..so get 90-91 integra clutch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lrcrx90 »</TD></TR><TR><TD CLASS="quote">he ordered it with the lsd and how would a b18 clutch fit</TD></TR></TABLE>
because the 90-91 b-series tranny uses the same clutch and the 92-01 b-series tranny uses a different clutch....trust me it works ,gotta clutch kit for 90-91 integra in my 90 b16 tranny right now ..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lrcrx90 »</TD></TR><TR><TD CLASS="quote">also distrubitor cap rotor inside spark plug wires,valve gasket ect. which one would i buy from del sol or si</TD></TR></TABLE>
for cap,and rotor you can use 90-91 integra or 88-91 civic...it all works....for valve cover gasket kit i order 99-00civic si and im sure the del sol b16 works also....
EgSalad
Nov 29, 2003 12:06 PM
