Need Help with turn signals ASAP!!!!!!!!!!!
Ok ive done research and cant find anything related to this problem. I got a 96 integra gs and the front end was stolen off of it and the cut the turn signal lights. i got new clips and when i wired them up the passenger side only blinks when the hazzards are on. other than that they dont blink at all?? they turn on as running lights when the regualar lights are on.
Ok so there were 5 wires where they cut the plugs off of and they are 6 wires with both plugs. do i wire the red ones all into one?
these are the following wire colors: G/B, G/Y, 2 Blacks and 1 red.
Ive checked all the wiring and that. but what fuses control the blinkers? where are they located inside or out?
I need help ASAP!!!!!!!! anything please!!!
You got one wrong plug (but you can still get it to work). One plug should be single filament(2 wires) and the other dual filament (3 wires).
green/blue-turn signal; red/black-parking lights; black-ground are together on the dual filament plug
green/white(G/Y is passenger side)-side marker light; black-ground is on the single filament plug
Ok i tried hooking them up but what does that last red wire hook up to? i tried splicing it into the other red wire and when i go to turn them on only one side blinks? i dont know what to do with these wires... I need help ASAP please!!!!!!!
Syper
Dec 1, 2009 05:04 PM
slikz714
Jun 1, 2006 06:46 PM
