what octane gas to run
Old Jun 18, 2006 | 12:24 PM
steve96accord's Avatar
Default what octane gas to run
i run 93.. but my friend has a accord same year f22b2 an i can member if after ur boost a car do u go from 87 to 93 or does that come halfer u build the block?
Old Jun 18, 2006 | 12:52 PM
philadd's Avatar
Default Re: what octane gas to run (steve96accord)
Once you add boost, you need to run 91 or 93 octane (or higher), whichever is available in your area. Whether you block is built or not shouldn't matter unless you run a higher compression, which most likely would not be the case.
Old Jun 18, 2006 | 01:23 PM
Leo C's Avatar
Night Owl
If your car requires premium, run premium. A stock 5th gen accord ex will not require premium and will run better, get better mileage and be faster if you use regular.
Old Jun 18, 2006 | 01:37 PM
Default Re: what octane gas to run (shutupnskate)
Thanks Alot........
Old Jun 18, 2006 | 01:41 PM
Leo C's Avatar
Night Owl
If you build the block for higher compression or advance the timing or have any sort of forced induction, then run the highest octane you can find( 93 in some areas). If your F22 engine is stock, run premium.
Old Jun 18, 2006 | 01:42 PM
k thanks
Old Jun 18, 2006 | 02:59 PM
philadd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutupnskate &raquo;</TD></TR><TR><TD CLASS="quote">If your F22 engine is stock, run premium.</TD></TR></TABLE>
You mean, if your engine is stock, run regular.
Old Jun 18, 2006 | 03:06 PM
Leo C's Avatar
Night Owl
Default Re: what octane gas to run (philadd)
yep my bad I stand corrected on me
flat out 99
Jan 17, 2012 02:32 AM
code_basher
May 23, 2008 08:08 PM
See Are X
Sep 14, 2006 05:25 PM
patdemps
May 11, 2004 07:57 PM
CrOmEdOmEcHaMbEr
10
May 9, 2002 11:41 AM
