Wire tuck experts, quick question.
Old Jun 18, 2006 | 07:15 AM
CRXBart's Avatar
Default Wire tuck experts, quick question.
I started doin my wire tuck and engine bay shave. All the pass side plugs are pulled inside, and I'm about to start welding holes. Now for the driver's side, what do you do with the wiring comming through there? Pics would be a great help. I'm guessing the engine wiring plug, and brake MC wires need to stay, but I should seperate the headlight/indicator wired, and run them back inside, then through he framerail. Does this sound right? Thanks in advance. Yes I have searched, and have not found a picture of this.
Old Jun 18, 2006 | 08:23 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: Wire tuck experts, quick question. (CRXBart)
yea that sounds right, only wires that need to stay in or the mc wires.
Old Jun 18, 2006 | 08:39 AM
CRXBart's Avatar
Default Re: Wire tuck experts, quick question. (floss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by floss &raquo;</TD></TR><TR><TD CLASS="quote">yea that sounds right, only wires that need to stay in or the mc wires.</TD></TR></TABLE>
what about the engine harness plug?
Old Jun 18, 2006 | 10:59 AM
CRXBart's Avatar
ttt
Old Jun 18, 2006 | 11:09 AM
hatchinprogress's Avatar
id like to know also ( i think its some time for a wire tuck)
Old Jun 19, 2006 | 06:08 AM
i pulled that halfway through. it wont go all the way through cause the plug is a lil too big. i might take some pics after work to help ya out.
Old Jun 19, 2006 | 09:37 AM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by floss &raquo;</TD></TR><TR><TD CLASS="quote">i pulled that halfway through. it wont go all the way through cause the plug is a lil too big. i might take some pics after work to help ya out.</TD></TR></TABLE>
That would be awesome!
Old Jun 19, 2006 | 10:23 AM
onepoint6i's Avatar
good luck with future ground problems..
Old Jun 19, 2006 | 10:41 AM
CRXBart's Avatar
Default Re: Wire tuck experts, quick question. (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">good luck with future ground problems.. </TD></TR></TABLE>
If I didn't think I was capable of doing it, I wouldn't attempt it. Everything will be soldered, heat shrinked, flex loomed, and taped. I'm not a ricer that half asses ****, like most of the people you talk down to. The only reason I'm doing this, is because the K swap uses new wiring throught the bay anyway. I f I didn't have to change a bunch of crap to start with, I wouldn't do the shave, but I'm gonna do it now, and weld all the unused holes shut too. Even though it is not a show car by any stretch of the term, but if I'm going to do something it will be done right. IF I have a ground problem you can say I told you so, but I highly doubt it.
Old Jun 19, 2006 | 01:57 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">
If I didn't think I was capable of doing it, I wouldn't attempt it. Everything will be soldered, heat shrinked, flex loomed, and taped. I'm not a ricer that half asses ****, like most of the people you talk down to. The only reason I'm doing this, is because the K swap uses new wiring throught the bay anyway. I f I didn't have to change a bunch of crap to start with, I wouldn't do the shave, but I'm gonna do it now, and weld all the unused holes shut too. Even though it is not a show car by any stretch of the term, but if I'm going to do something it will be done right. IF I have a ground problem you can say I told you so, but I highly doubt it. </TD></TR></TABLE>
wow..ok..
half the people i talk down to eh!
i dont know if to take that as a compliment or otherwise..
but good luck anyways..
Old Jun 19, 2006 | 04:03 PM
Rywire's Avatar
Its real ez man. You can run the wires around the fender (as seen in my stg2 thread). Then, for the wiper motor, and the MC you can run those to the bay on there own.
Old Jun 19, 2006 | 06:17 PM
CRXBart's Avatar
Default Re: Wire tuck experts, quick question. (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Its real ez man. You can run the wires around the fender (as seen in my stg2 thread). Then, for the wiper motor, and the MC you can run those to the bay on there own. </TD></TR></TABLE>
I got all of that, and I have no wiper so I don't need to do that. I'm just wondering about the engine harness plug on the driver's side. You need to hurry up, and finish your and take lots of pics, so I have a template to copy off of.
Old Jun 19, 2006 | 07:32 PM
Rywire's Avatar
The eng harness plug on the drivers side can come into the cabin. Do you have a si? If so, that plug will be left disconnected
Old Jun 19, 2006 | 07:50 PM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">The eng harness plug on the drivers side can come into the cabin. Do you have a si? If so, that plug will be left disconnected</TD></TR></TABLE>
Yes I have an Si. Should I just go ahead and remove that wiring from the car? I wanna simplify things as much as possible, and I don't want a bunch of plugs dangling unplugged. I still have to remove the rest of my HVAC system wiring, wiper wiring, washer system wiring, and sun roof wiring. I bet I'm gonna save 10lbs in just wire. What is the plug on the driver's side for anyway injectors?
Old Jun 19, 2006 | 08:42 PM
Rywire's Avatar
Yes, some injectors, iacv, exc... all the stuff in the k harness. Be carefull when simplifying the harness... Just be carefull.
I have yet to do mine, I have disconnedcted plugs allover the place under my dash...
Old Jun 19, 2006 | 08:44 PM
Rywire's Avatar
oh, dont eliminate the other shock tower plugs though... You need the ugly grey plug with the lithiam greese in it, and the 6 pin... The PNP harness will use those... They will also use like 7 wires at the ecu
Old Jun 19, 2006 | 08:53 PM
CRXBart's Avatar
sweet I have all the plugs on the driver's side intact and pulled inside. I scored a virgin non-ac block off plate at the yard today. One less hole to fill. I'm gonna work on the driver's side plug tomorrow now.
Coopa B18c5
Apr 29, 2013 10:37 AM
Mixmasta
Jan 27, 2009 05:32 PM
i_kick_turtles
May 27, 2007 09:54 PM
Turbo Dan
13
Jul 7, 2006 09:15 AM
accord2k_guy
Mar 21, 2002 11:43 AM
