tach signal, ok to use the white wire? (B15)
I'm hooking up serveral sensors to a datalogging device, it's a long story but I would rather get the signal from the ECU area. just wonering if the white wire @ B15 @ ECU is exactly the same as the blue wire that goes to the cluster?
The wires are not spliced in the wiring diagram, they come very seperate terminals on the ignitor. Why did honda do this? is it ok to tap into this signal?
thanks.
thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 »</TD></TR><TR><TD CLASS="quote"> just wonering if the white wire @ B15 @ ECU is exactly the same as the blue wire that goes to the cluster?
That's the ignition output signal. The ecu uses it to tell the igniter when to fire the coil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">That's the ignition output signal. The ecu uses it to tell the igniter when to fire the coil. </TD></TR></TABLE>
Thanks for the 411! I wonder if it will have any sort of undesirable offset?
beatthisspeed69
19
Aug 2, 2007 08:46 AM
HondaCivicSiR1
22
Dec 13, 2004 10:38 AM
