Speed Sensor/Signal on wire harness..
I think my wire harness is OBD0 and the ECU connectors looks like this.
What color code is the speed sensor/signal on the wire harness to the ECU color code?
Thanks.
Thanks.
im having trouble with this too... i know that b16 (yellow/red) is the where the sensor goes, but from the speedo clip harness.. it has a black, yellow and yellow/white... the black is the ground... which is the 12v and which goes to the yellow red, also where is a good place to wire up the 12v
bump for a little for info
ferio-ichi3
Jul 13, 2015 09:39 AM
axis11
Honda CR-V & Element
Mar 30, 2015 01:15 AM
