need some advice on the rsx motor
well here is the thing, im getting my motor replaced by acura they are putting a brand new motor in..so my question is am i getting k20a2 motor or k20z1 motor??? and once i get my car back how can i check which one i have???
why would i be kidding??? https://honda-tech.com/zerothread?id=1646011 check out the thread Refuse2besmart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 25Type-s »</TD></TR><TR><TD CLASS="quote">why would i be kidding??? https://honda-tech.com/zerothread?id=1646011 check out the thread Refuse2besmart</TD></TR></TABLE>Still can't believe you got smithtown to do it for you....
Something that I definitely don't miss about being out on LI is that place and those monkeys there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow »</TD></TR><TR><TD CLASS="quote">Still can't believe you got smithtown to do it for you....
Something that I definitely don't miss about being out on LI is that place and those monkeys there.</TD></TR></TABLE>
Yea i was really surprised they are doing it for me i should have the car back either tuesday or wendsday..
more than likely, they will replace it with the same engine that came in the car. a2. Simply speaking, that is what was busted, so that is what will go in. No sense in replacing with z, and then also changing the ecu etc...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow »</TD></TR><TR><TD CLASS="quote">more than likely, they will replace it with the same engine that came in the car. a2. Simply speaking, that is what was busted, so that is what will go in. No sense in replacing with z, and then also changing the ecu etc...</TD></TR></TABLE>
so they just have the a2 lust laying around just in case something like that happens???
they may try to source one from local boneyards. I doubt that a brand new o2 assy is sitting around waiting to be put in. But maybe I am wrong.
Andrey
Oct 23, 2007 02:36 AM
poorman's type-r
Dec 17, 2005 10:30 PM
