whats wrong with my e-brake
have a 91 crx si came with rear disc stock and did teg brake swap up front with 91 civic ex nuckles teg brak booster and mc and propotin valve swapped out and when i did them ireplace the rotor with slotted and drilled brembo rotors with axxis pads and ever since i did the swap my ebrake does not lock up anymore i tryed adjusting the e-brake handle but still does not lock up what shouild i try to do do you think it could be the [ads if there cheap ones dont no thanks
the lock is on the user side of the ebrake assembly if im not mistaken. I dunno, take it apart?
Im wondering why you messed with the brakes at all. 4 wheel disc brakes to stop a CRX is plenty my friend.
civbeater90
34
Aug 1, 2002 06:08 AM
