converted to obd1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***-assin »</TD></TR><TR><TD CLASS="quote">resistor box can go as well.</TD></TR></TABLE>
Only if you converted to OBD1/2 injectors.
It is only dependant on your injectors. If you keep the pre-obd (obd0) injectors, you need to keep the resistor box. You can run these with any ecu. Same thing on the OBD1 injectors....you can use them w/o the resistor box on the pre-obd (obd0) ecu..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91cleancrxsi »</TD></TR><TR><TD CLASS="quote">i have already gotten rid of the resister box but do i get rid of the charcol canister and how would i do that</TD></TR></TABLE>
you can get rid of the charcoal canister. just leave the EVAP sensor vent to open air and plug the fuel vapor return line. i've done that and no problems so far.
mr. Grind
Aug 13, 2004 04:08 PM
