Radiator question
Greetings.
Short and sweet. Will the '92-'00 Civic half rad be enough cooling for my build? I'm almost positive it will be but I wanted to double check.
My build.
D16Z6 into a '91 Civic Si hatch with OBD1 conversion and P28 ECU (basemap by PissedOffTuning and chipping by J-K-Tuning.com):
Block
75.5mm bore
Nippon Racing P28 pistons
9.5:1 c/r (block decked .007" and head milled .008")
OEM Honda head gaskets and bearings
Head
ARP head studs
Comp Cams 59300
Comp Cams springs and retainers
Skunk2 Cam gear
Stock IM with eBay Hondata gasket
No port work
Transmission
11.5lbs. flywheel
Exedy stock clutch
'91 CRX Si tranny
I/H/E
AEM CAI
DC 4-2-1 two piece
GReddy SP catback
Magnaflow 2" cat
My build.
Block
75.5mm bore
Head
ARP head studs
Comp Cams 59300
Skunk2 Cam gear
No port work
Transmission
11.5lbs. flywheel
Exedy stock clutch
'91 CRX Si tranny
I/H/E
AEM CAI
DC 4-2-1 two piece
GReddy SP catback
Magnaflow 2" cat
MikeB20v
Dec 6, 2016 07:00 AM
