hood chipping
Old Jun 17, 2006 | 05:00 PM
playahwitgame's Avatar
Default hood chipping
i accidently closed my hood with something on the valve cover, and it kind of made an indentation and made the hood chip, not bymuch, but im worried about it becoming worse, what can i do?
Old Jun 17, 2006 | 05:04 PM
__oversea's Avatar
Default Re: hood chipping (playahwitgame)
mm? so you mean paint chiped off? if you are soooo worried, go buy yourself a touch up paint and apply there. since its under the hood, it doesnt have to be pretty
Old Jun 17, 2006 | 05:05 PM
Default Re: hood chipping (Last For One)
not under hood
mike9571's Avatar
The only way to stop a chip from getting worse is to sand it so its a flat surface. (no hard edges)
As far as the indentation hammer and dolly it smooth.
Old Jun 17, 2006 | 05:12 PM
Default Re: hood chipping (mike9571)
no idea how to do that stuff, how much do you think itll charge at an auto shop? its about 1 square inch, probably less
Old Jun 17, 2006 | 05:13 PM
mike9571's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playahwitgame &raquo;</TD></TR><TR><TD CLASS="quote">no idea how to do that stuff, how much do you think itll charge at an auto shop? its about 1 square inch, probably less</TD></TR></TABLE>
Get pic up, then I could tell you
Old Jun 17, 2006 | 05:24 PM
how do i put in a picture saved on my comp?
Old Jun 17, 2006 | 05:33 PM
mike9571's Avatar
Go to a website like http://www.photobucket.com
Upload your pictures from your hard drive.
Right click the picture when its uploaded and go to properties.
Copy the link down, it should end in ".jpg"...if it ends in ".orig.jpg" then take off the ".orig"
Go to Honda Tech
Insert your link between image tags
Sample:
Here is my dyno:
(img)www.photobucket.com/myshit.jpg(/img)
Except instead of () for the brackets, use []
Thats it!
Old Jun 17, 2006 | 05:38 PM
the lighting makes it look liek a huge indentation as it was taken in the dark with a camera phone, im just worried about the chipping
Old Jun 17, 2006 | 05:40 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Go buy some 300grit sand paper and sand around it a small amount,
and then just spray over it a little if you want a cheap fix from any rust.
Old Jun 17, 2006 | 05:41 PM
Default Re: hood chipping (FlatBlackTeg)
how do i get the same paint color
Old Jun 17, 2006 | 05:42 PM
mike9571's Avatar
just sand the hard edges smooth.
Old Jun 17, 2006 | 05:45 PM
i get that, but then what, there is paint tht has come off already
Old Jun 17, 2006 | 05:46 PM
mike9571's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playahwitgame &raquo;</TD></TR><TR><TD CLASS="quote">i get that, but then what, there is paint tht has come off already</TD></TR></TABLE>
Not sure what you mean
Old Jun 17, 2006 | 05:47 PM
well the paint has chipped, there are a few speckles of the metal coming through, i dont want to have green around, and then some bare metal
Old Jun 17, 2006 | 05:50 PM
mike9571's Avatar
1st- smooth it out (hammer&dolly)
2nd- Sand hard edges off
3rd-use filler if needed
4th- prime
5th- paint
Old Jun 17, 2006 | 05:51 PM
so how much would it cost at a body shop
Old Jun 17, 2006 | 05:57 PM
so how much am i looking to pay
Old Jun 17, 2006 | 06:10 PM
__oversea's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playahwitgame &raquo;</TD></TR><TR><TD CLASS="quote">so how much am i looking to pay</TD></TR></TABLE>
noone can tell you the real price. but you are looking at around 150-200
Old Jun 17, 2006 | 06:15 PM
mike9571's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Last For One &raquo;</TD></TR><TR><TD CLASS="quote">noone can tell you the real price. but you are looking at around 150-200</TD></TR></TABLE>
Take it to some shops and they can quote you.
Old Jun 17, 2006 | 06:21 PM
Uncle Willie's Avatar
I bet its more than that. They would probably just replace the whole hood, then prime it, block sand it (no low or high spots), paint it, the wetsand it, then buff it.
One of the other shop that i work at closed a hood on a ratchet on an Infinitti. Same problem as urs. Guy to it to dealer to get it fixed=700$.
Just expect a high price to get it fixed if you want it to last. If you go to some cheap *** place, i bet the clear will start to peel off in about a year.
Old Jun 17, 2006 | 06:23 PM
Default Re: hood chipping (RIP Indian Larry)
its really not a big indentation at all, the picture maes it look really bad, its just the glare from the flash
Old Jun 17, 2006 | 06:26 PM
mike9571's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playahwitgame &raquo;</TD></TR><TR><TD CLASS="quote">its really not a big indentation at all, the picture maes it look really bad, its just the glare from the flash</TD></TR></TABLE>
Fixing the actual high spot isnt the expensive part. Painting the hood is
Old Jun 17, 2006 | 06:27 PM
gsr dood's Avatar
NO WAY !!!!!!! u dont need to replace it. i work at an autobody shop. we would smack that in with a hammer and a punch then apply sum filler sand a prime....keeping the work area within 3 or 4 inches and blendin......its no more than 150$
Old Jun 17, 2006 | 06:31 PM
mike9571's Avatar
Default Re: hood chipping (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">NO WAY !!!!!!! u dont need to replace it. i work at an autobody shop. we would smack that in with a hammer and a punch then apply sum filler sand a prime....keeping the work area within 3 or 4 inches and blendin......its no more than 150$</TD></TR></TABLE>
Yea I work at a body shop too. That is a veerryy easy fix for a body shop.
