clutch noise
Old Jun 17, 2006 | 04:40 PM
NAtuned's Avatar
Default clutch noise
i just recenlty installed an act 6 puck sprung clutch w/ a lightened flywheel and i hear a noise whenever the car is running. when i touch the clutch pedal the noise stops. also i feel vibration in the pedal. anyone know what the problem is
Old Jun 17, 2006 | 04:43 PM
__oversea's Avatar
Default Re: clutch noise (NAtuned)
was it installed right?? every bolt was tighten in spec? could be pedal adjust problem. or disenguage problem. did you bleed the line after installed?
Old Jun 17, 2006 | 04:51 PM
NAtuned's Avatar
Default Re: clutch noise (Last For One)
the a**hole mechanic said he bleed the clutch line and put gear oil in the tranny but he didn't grease the bearings.
im thinkin its the bearings but that vibration feel is crazy.
how do you adjust a hydraulic transmission?
ever heard of using motor oil in the transmission instead of gear oil?
Old Jun 17, 2006 | 04:56 PM
__oversea's Avatar
you can use motor oil. but i wouldnt. go buy yourself a honda MTF. you need 3Q. and do it yourself/ pretty easy with few tools.
http://www.c-speedracing.com/howto.php
and about the adjust. press search
frostykue
Apr 1, 2012 09:23 PM
lxdriver
Jan 18, 2011 07:09 AM
JDMpride
13
Nov 18, 2010 08:10 AM
93b20z
Transmission & Drivetrain
Mar 30, 2009 06:15 AM
Junkyard2000
11
Dec 20, 2005 11:51 AM
