gsr skunk 2 manifold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z51C6 »</TD></TR><TR><TD CLASS="quote">i heard people have problems w/ the skunk2 intake manifold upgrade..is this true? because i want to know because i want to also upgrade to skunk2 intake manifold and cams.</TD></TR></TABLE>
I have a gsr motor with a skunk2 manifold. I never had problem once. Only thing is running the p72 ecu on it wont make alot of power cause the the skunk2 im is a single stage runner while the p72 ecu has a secondary butterfly. You can take it to a local tuner shop and disable the secondary butterly or just get a p28 chip with a custom base map for your car. With the skunk im on, it pulls better on high rpm.
you need ITR TB cable and ITR TB holder and ITR TB pully. otherwide it will hit the hood.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z51C6 »</TD></TR><TR><TD CLASS="quote">i have a 95 gsr so that means my ecu is p72? and i always have to get dyno tune once i upgrade intake manifold right?</TD></TR></TABLE>
for OBDI not required. for OBDII 97-01 need to setup ECU for dis program the 2ndery butterfly.
it all depends
if u want ur GSR stock strut bar, u need ITR throttle pulley, cable and bracket, otherwise the stock unit will interfere.
if u dont have a GSR strut bar, the GSR OEM stuff will work ok, but will look out of place.
if u have a GSR AEM CAI with a bypass, your intake will still work A-OK. other GSR intakes im not sure.
this is what u get when u use GSR throttle pulley, cable and bracket, and the OEM GSr strut bar:
it will rub like crazy
what about a gsr shortram intake..i also heard for cold air intake the Ls intake works the best w/ the intake manifold.</TD></TR></TABLE>
Dont waste money on a aem ls cold air intake, get the aem ITR cai cause its 3 inch.
ls cable and bracket work just fine with out changing the pullely
u can even use the stock gsr temporarily but it will hit the hood and casue the throttle to stick at about 3krpm
or use the stock pulley and cable and make your own bracket, its very very easy, and can look very clean as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akstunt600 »</TD></TR><TR><TD CLASS="quote">ls cable and bracket work just fine with out changing the pullely
i had my stock GSR stuff on for a week and nothing hit nor stuck.
personally i think the gsr intake manifold is better, it has more torque for low end (the whole reason for the secondary butterflies)
i put a skunk2 on my car when it was NA, and took it off after a week, lost so much mid and low end power, not worth it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkrone »</TD></TR><TR><TD CLASS="quote">personally i think the gsr intake manifold is better, it has more torque for low end (the whole reason for the secondary butterflies)
i put a skunk2 on my car when it was NA, and took it off after a week, lost so much mid and low end power, not worth it </TD></TR></TABLE>
Yup you do lose low end power but you gain more high end power than stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8gsr_teg »</TD></TR><TR><TD CLASS="quote">Yup you do lose low end power but you gain more high end power than stock. </TD></TR></TABLE>
the where is the horsepower gain? the key operating range for skunk2 intake manifolds is 7000-10,000 rpm, you will not see any gain below that, for the few hundred rpm you are in before shifting with stock internals
tomlinson619
Apr 14, 2006 04:26 PM
InTeGrA B18b1
Aug 28, 2002 07:34 PM
my gsr skunk 2 im
