Distributor problem.
Yes, i have done the allmighty search without any luck.
My distributor has ceased to deliver spark to my plugs. Therefore it doesnt ignite anymore.
Im clueless. I've checked all fuses, i've measured the wirings, checked all connections. Still no answers to be found. Any suggestions?
Have you checked to make sure the rotor is still attached? I know it sounds stupid but its happened. Also, check your ignitor and make sure it is within spec.
i checked all the fuses. But though, the fuse may be bad even if its not visible.
I dont have a diagram over the fuses in the "cockpit" (dont remember the word so bear with me).
Anyone have a picture?
Cheers.
Cheers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 »</TD></TR><TR><TD CLASS="quote">ECU?</TD></TR></TABLE>
Tried replacing that as well.
If you swear to god that you already checked all the wiring than the only other thing that I can see in the diagram for the circuit is the ignition switch. That is where the igniter gets its power from.
i would check your wireing.. if u have a volt meter u can check for breaks in the wire to the dizzy.. i had the same problem i had to re run a wire and pin it in the right ecu spot on plug c...i dont remember exactly what spot it goes into..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 »</TD></TR><TR><TD CLASS="quote">If you swear to god that you already checked all the wiring than the only other thing that I can see in the diagram for the circuit is the ignition switch. That is where the igniter gets its power from.</TD></TR></TABLE>
are you looking at the VTEC pdf manual?
If so, what page should i be looking at? I got like 1-2 hours to work on this every day. thats not much. Help me as much as possible please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaCk »</TD></TR><TR><TD CLASS="quote">
If so, what page should i be looking at? I got like 1-2 hours to work on this every day. thats not much. Help me as much as possible please. </TD></TR></TABLE>No a non vtec USDM service manual, but it should make no difference either way.
ok you swear all wiring is correct I'm assuming ground too that eliminates that problem, only if you're correct though.
you swapped dizzy's also didn't work that rules that out.
you swapped ecu's that rules that out.
as long as all the wiring is correct than the only other component left in the circuit is the ignition switch. That is where the dizzy gets power from.
I still think it's the wiring though
GeoMetry
Dec 3, 2019 12:10 PM
2ndGenGsr
May 18, 2003 01:58 AM
