half shaft install w/o draining fluid?
Old Apr 16, 2002 | 06:05 PM
Lo-Buck EF's Avatar
Default half shaft install w/o draining fluid?
can i do a halfshaft w/o draining the fluid (ie-jack up one side of the car causing the fluid t collect ont he opposite side of the tranny) or will it come pouring out anyway when i pop the cv out of the tranny?
Old Apr 16, 2002 | 06:33 PM
infuryum's Avatar
Default Re:
It won't drain out.
smokin rubber's Avatar
Default Re: half shaft install w/o draining fluid? (SOLOef)
you could probably get away wih it but why? tranny fluid isnt that expensive and transmissions are. Just go to the dealership and pick up a couple quarts and change it. all you need is a funnel with a bundy extension and its cake, easier than an oil change.
Old Apr 16, 2002 | 06:45 PM
EP3_05's Avatar
It won't pour out. But if you haven't changed it in awhile why not just drain it and give it some fresh fluid.
Old Apr 16, 2002 | 06:52 PM
Lo-Buck EF's Avatar
Default Re: half shaft install w/o draining fluid? (91civic)
i definately have to change it. i think its been in there since the car rolled off the assembly line. but i've been tryin to get it done for a week and its been one thing after another. just wanted to know just in case i ended up doin the shaft sat. night after everything closes with a race to go to on sunday. if i get to it earlier (hope so) i'm gonna do it.
thanx
Old Apr 16, 2002 | 10:12 PM
salbaje's Avatar
usually if you jack up the car evenly it wont drain out. maybe a little but not much
aries331
Dec 1, 2007 01:13 PM
kornerk12
Nov 18, 2005 05:37 AM
Mavrick
Nov 10, 2005 12:52 PM
2k1_ITR_0736
Jan 28, 2003 06:37 AM
