Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Autozone brake pads....
Old Apr 16, 2002 | 05:57 PM
KekeK-18's Avatar
Default Autozone brake pads....
Some one mention they have bought some (autozone, pepboy?) brake pads before with very good result. Anyone remember or know what brand are those? I need a set for the rear mainly for autox and open track events.
Old Apr 16, 2002 | 06:07 PM
Drew M's Avatar
New User
Default Re: Autozone brake pads.... (KekeK-18)
Wearever available at Advanced Auto Parts
Old Apr 16, 2002 | 06:34 PM
MaddMatt's Avatar
Default Re: Autozone brake pads.... (Cobra)
Since you
A) have a turbo according to your sig, and
B) want to do track days,
I sure as hell would not use those on the front. On the back will be fine. All the rear does is keep the gas tank from dragging....
Old Apr 16, 2002 | 06:51 PM
KekeK-18's Avatar
Default Re: Autozone brake pads.... (MaddMatt)
Thanks guys, yeah I'm currently running Porterfield pads in the front and think I can get away with it in the REAR with some autozone pads.
Old Apr 16, 2002 | 06:56 PM
Mike P.'s Avatar
25 Year Member
I recently stuck a set of Raybestos PG Plus pads in the rear calipers on mine's. Used them for a weekend at VIR, too....not an ounce of problem with them, and they were quite inexpensive, checking out at round-about $30 at Pepe Boyz.
Old Apr 16, 2002 | 08:03 PM
.RJ's Avatar
.RJ
Default Re: Autozone brake pads.... (Mike P.)
If you have a lightweight, low powered vehicle, you can use Autozone severe/extreme duty (forget which one) pads. They're tough as hell, and they'll last. Not the best stopping brakes, but they wont melt into oblivion on the track and they're cheap. For a 12 second turbo car? I'd be very leery... A friend of mine has a turbo eclipse and he was pushing 130+ on the back straight at Summit Point using street tires during a FATT. I made him buy some P+ before that event...
RJ
Old Apr 16, 2002 | 08:39 PM
GRM Scott's Avatar
25 Year Member
look into some AEM pads maybe...i'm runnin them in the rear, they seem pretty good (have porterfield R4S up front for street, Carbotech P+ for track), and aren't that expensive...plus, the fit is OEM since they're made by nissin, I had to fuggin dremel down the sides of some god-knows-where pads that were put on my girlfriend's LS right before she got it, they were so tight that they wouldn't contact the rotor unless they were at an angle
Old Apr 16, 2002 | 08:46 PM
KekeK-18's Avatar
Default Re: Autozone brake pads.... (Type-RJ)
I need good pads in the REAR too?? I can lock my tires up if I want to with Porterfield in the front and cheezy pads that I bought from some no name autoparts store in the rear, with stock calipers and rotors. The rear only have 20% or so braking power, right?
Old Apr 16, 2002 | 08:51 PM
.RJ's Avatar
.RJ
stock pads in the rear are just fine...
Old Apr 17, 2002 | 04:31 AM
Lo-Buck EF's Avatar
yea guys, he's talkin about thr REARS.
i think u should be fine with whatevers in the rear. there was a thread a while back on pads discussing p+ pand on the track and most people were running nothing special in the rers with good ones up front.
Old Apr 17, 2002 | 08:50 AM
sazemaster's Avatar
New User
Default Re: Autozone brake pads.... (SOLOef)
yeah am running some no-name autozone brand pad in the back with no problems. mine are up for replacement now and i will just get some more of the same. ( i think they even had some sort of lifetime warrantee i can cash in on?? gotta go dig up my receipt) cant beat it for under $20 a set for my civic. but i would definitely run a good pad up front.
tom
[Modified by sazemaster, 12:50 PM 4/17/2002]
[Modified by sazemaster, 12:51 PM 4/17/2002]
Old Apr 17, 2002 | 09:51 AM
MaddMatt's Avatar
Default Re: Autozone brake pads.... (sazemaster)
I've got about 11 events so far on the $9 Wearever Silver (not even the Gold!!) pads on the back on my SE-R. I might replace them this year....
Old Apr 17, 2002 | 10:13 AM
Tyson's Avatar
Which porterfields did you use? the street or the race ones? My data point is that the street ones DO NOT hold up well under racing conditions. Since I had em around I put them on the last day of drivers school at the track and used them my last race. I was better off with street pads, they just crumbled and scored my rotors. And lasted only 6 sessions (i dunno, maybe thats decent... im not happy with that tho). Im not gonna bother with trying the race pads anyway, Im gonna go Blue. So just my warning to anyone with street/autox Porterfields going to a HPDE event or such, expect them to wear more than they do on the street, however I never did get to use them on the street anyway.
specbb6
Suspension & Brakes
Jan 8, 2013 06:28 PM
Steppin Razor
14
Mar 24, 2004 04:07 PM
mugenracer
Jun 19, 2002 05:53 PM
onyx00
Oct 19, 2001 03:34 PM
nonbox
Aug 23, 2001 04:47 AM
