Where is the best place to mount the Viper brain?
Old Jun 16, 2006 | 08:13 PM
Halo's Avatar
Default Where is the best place to mount the Viper brain?
I went to a shop to look at alarms..the guy at the shop said he can mount the brain wherever I want..Can anyone share their ideas?
Old Jun 16, 2006 | 10:18 PM
siggy833's Avatar
Default Re: Where is the best place to mount the Viper brain? (Halo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Halo &raquo;</TD></TR><TR><TD CLASS="quote">I went to a shop to look at alarms..the guy at the shop said he can mount the brain wherever I want..Can anyone share their ideas?</TD></TR></TABLE>
Way up in the dash so not even YOU can get to it to mess with.....
Old Jun 16, 2006 | 10:19 PM
dcautogroup's Avatar
well if your worried about it mount it behind your glove box
thats were i did mine ....everybody always mounts theres under driverside of the dash
nobody would think about passenger side
Old Jun 17, 2006 | 07:45 AM
fcm's Avatar
fcm
Old Fart
Default Re: Where is the best place to mount the Viper brain? (dcautogroup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Halo &raquo;</TD></TR><TR><TD CLASS="quote">I went to a shop to look at alarms..the guy at the shop said he can mount the brain wherever I want..Can anyone share their ideas?</TD></TR></TABLE> There are more then a few places to mount the brain, two things you want to keep in mind are stealth and serviceability, you want it reasonably hidden but also serviceble....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siggy833 &raquo;</TD></TR><TR><TD CLASS="quote">
Way up in the dash so not even YOU can get to it to mess with..... </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcautogroup &raquo;</TD></TR><TR><TD CLASS="quote">well if your worried about it mount it behind your glove box
nobody would think about passenger side </TD></TR></TABLE> The second place I would look.
A good spot is behind the instrument cluster, well hidden and inaccessible without removing the cluster, easy to hide wiring, wiring is also short as possible, as most connections are on the drivers side. 94
Old Jun 17, 2006 | 03:45 PM
Default Re: Where is the best place to mount the Viper brain? (fcm)
or someone can just disconnect your battery
and would you have time to check a second place?
the alarm going off-people are wakeing up,looking out windows ,ect
if its a good alarm and its hooked up right started kill should be installed so even if its un pluged it wont start
and some one who wants to steal your radio wont worry about un hooking your alarm
Old Jun 17, 2006 | 05:19 PM
8520's Avatar
Yeah, but who really pays attention to alarms anyways?
Old Jun 17, 2006 | 06:56 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">or someone can just disconnect your battery </TD></TR></TABLE>
Battery backup will solve that problem...
Old Jun 18, 2006 | 01:22 PM
Halo's Avatar
Default Re: (B18C_EJ8)
What about under the seat and under the carpet? Electronic hood lock is mandatory
Old Jun 18, 2006 | 02:03 PM
tha_badguy's Avatar
What is that?
A Popper?
Only problem I see with that is when ur battery dies how u gonna open ur hood
Old Jun 19, 2006 | 11:14 PM
romoracing's Avatar
Default Re: (tha_badguy)
well it all depends on the car. I look where all the wires are and then determine where the brain is going to go. on most honda's I put it behind the sterring col. It takes sometime to get it in there because you have to drop the sterring col. but theres a bolt up there that i just remove and mount the brain onto it. Just one warning its a pain to work on it if it something goes wrong.
Old Jun 20, 2006 | 02:28 PM
NVturbo's Avatar
O.G. triple O.G.
Im really think about relocating mine above the glove compartment. My Civic is a 92 so it did not come with a P/S airbag. I'm just being lazy right now.
Old Jun 21, 2006 | 06:38 PM
siggy833's Avatar
Default Re: (romoracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romoracing &raquo;</TD></TR><TR><TD CLASS="quote">well it all depends on the car. I look where all the wires are and then determine where the brain is going to go. on most honda's I put it behind the sterring col. It takes sometime to get it in there because you have to drop the sterring col. but theres a bolt up there that i just remove and mount the brain onto it. Just one warning its a pain to work on it if it something goes wrong.</TD></TR></TABLE>
Remind me never to have you install anything in my car...That is absolutely the first place a theif will look if he is tryin to bypass your alarm, which ultimately leads to stealing your ride. Just my 2cents.
Old Jun 21, 2006 | 11:32 PM
romoracing's Avatar
Default Re: (siggy833)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siggy833 &raquo;</TD></TR><TR><TD CLASS="quote">Remind me never to have you install anything in my car...That is absolutely the first place a theif will look if he is tryin to bypass your alarm, which ultimately leads to stealing your ride. Just my 2cents.</TD></TR></TABLE>
Im not going to tell you where exactly im going to mount the brain. I just said behind sterring col. and didnt i mention that the only way to get to the brain is to drop the col? and did I mention what brains fit in that spot? no i didnt not. when i gets down to the bigger brains like the 791 there is not way it will fit back there but the sat. will. thats when i mount the box behind the gauges. Ive had my share of stolen cars so trust me im not going to tell people where i mount the brain and where all the kill swicths are mounted. im a newer installer but I spent countless hours perfecting my alarm installs. Ive searched to find the best ways to install. but hey what ever man take your car to some guys thats going to get your car out in 1 hour. My installs only take the whole day from 8am to about 6pm. So i dont mess around. hey i can get your car out by 4 hours I do it at best buy all the time. but thats me being fast and trying to be clean. dosnt work.
But hey its your car. do whatever you want
Old Jun 22, 2006 | 10:42 AM
siggy833's Avatar
But hey its your car. do whatever you want</TD></TR></TABLE>
OK don't get your panties in a bunch...I'm really glad that you do take pride in your installs. Alot of people now dayz just wanna get the job done and don't care. I have seen some spaghetti work out there. However, an 8 hour alarm install? Thats....well...unheard of. What does your manager at Best Buy think of all that? Where's the productivity in that? How do your customers feel about that? So you do 1 alarm a day? I have roughly 6 years of true install time and my alarm installs would never take me more than 3hrs. I don't mess around either. None of my alarms have ever come back because of install problems and 9 times outa 10 you can't find the brain.
So back to the original topic of discussion, whether you are droppin that nasty old steering column or not, Its still not the ideal place. And I still would never have you do an install on my car....
Old Jun 22, 2006 | 01:24 PM
rock~1's Avatar
i mounted my viper brain behind the intrament console, theres enough room and you have access to almost all the wires you need for hookups. there also is grounds around there that are easy to access. it also makes it easy to wire up the main power and the ignition wires, just run them down the plastic around the steering column. have fun tearing the car apart
Old Jun 22, 2006 | 01:31 PM
8520's Avatar
I have roughly 6 years of true install time and my alarm installs would never take me more than 3hrs. I don't mess around either. </TD></TR></TABLE>
You must not do any complicated alarm installs.
Old Jun 22, 2006 | 04:22 PM
romoracing's Avatar
no man i was mad or anything. but i can get a car out in 3 hrs but when people come and get a install at my house thats when i spend the time.
Old Jun 22, 2006 | 08:25 PM
siggy833's Avatar
Default Re: (a_s_ol_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a_s_ol_ &raquo;</TD></TR><TR><TD CLASS="quote">
You must not do any complicated alarm installs.</TD></TR></TABLE>
You wanna try me? Go ahead and tell me how you would wire a (1) spdt relay to activate a trunk release..and with the SAME relay wire it to pop the gas filler door...off of the SAME CHANNEL OUTPUT...but not simultaneously. Please don't get involved with this conversation if all you can do is talk ****...you will only make yourself look stoopid.
Old Jun 22, 2006 | 08:40 PM
siggy833's Avatar
I'm waiting for your response...I guess since it's taking you this long (cause I know your online)it means that you have Googled the question and whatever you cleverly type is from the internet and not from your smart mouth....
Old Jun 22, 2006 | 08:53 PM
siggy833's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romoracing &raquo;</TD></TR><TR><TD CLASS="quote">no man i was mad or anything. but i can get a car out in 3 hrs but when people come and get a install at my house thats when i spend the time.</TD></TR></TABLE>
Thats cool and all, but thats not what you originally said. You said that it takes you 8 hours to install an alarm at Best Buy while you are working...It's OK, FNG'z are sometimes cocky like that....It's OK...
Old Jun 23, 2006 | 12:07 AM
8520's Avatar
lol someone has their panties in a bunch
Old Jun 23, 2006 | 12:28 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
So back to the original topic of discussion, whether you are droppin that nasty old steering column or not, Its still not the ideal place. And I still would never have you do an install on my car.... </TD></TR></TABLE>
I'm a former professional installer. When I installed the Viper 791XV into my Civic, it took me three days.
Old Jun 23, 2006 | 10:17 AM
fcm's Avatar
fcm
Old Fart
I'm waiting for your response...I guess since it's taking you this long (cause I know your online)it means that you have Googled the question and whatever you cleverly type is from the internet and not from your smart mouth....</TD></TR></TABLE>Well I'm waiting for you to tell us exactly how you do wire one SPDT relay and using one EXT function and have it pop a trunk and pop the gas filler door, and not at the same time. 94
Old Jun 25, 2006 | 05:40 PM
suspendedHatch's Avatar
Default Re: (fcm)
Goddamned cocky people get on my nerves. If you were really as good as you think you are, you wouldn't have something to prove. So close your **** windows and go jerk off to your highschool yearbook crying like a bitch at your mom's house like you always do.
Only cars I've had any luck hiding the brain behind the cluster is on the fifth gen Civic and the Nissan 240SX, and I only really do that if it's remote start or if my favorite spot isn't do-able. Most cars I don't even bother trying to pull the cluster. Too much work. It's easy on the fifth gen. Barely any room back there and requires some plastic cutting. No space for a backup battery or piezo siren.
My favorite spot on nearly any 2 door Japanese car I've ever did a stealth install is under the side plastic next to the driver's side rear passenger. Virtually all your connections come down the running boards. There's plenty of room for a hidden interior siren, battery backup, and modules and relays, and a trunk popper. Only wires you have to run are the ignition, door locks, and hood trigger. Details and pics are on my site which no one has ever heard of. Big waste of time. http://www.vsracing.net/~suspended/
Good stealth install takes about 8 hours. 3 days? Maybe my first time. Maybe if I was only working a couple hours a day, or doing a complete security solution. Kill switches; a ghost switch and a deeply hidden one, reroute or remove hood release cable, slim jim/lock pick proofing the doors, putting a start kill in the engine bay... yeah that together with a stealth install might eat up 3 days.
How much are you charging labor on your side-job stealth installs? I'm charging $300, with discounts for cars that I am partial to.
Old Jun 25, 2006 | 08:59 PM
o0Jash0o's Avatar
Default Re: (suspendedHatch)
why not mount it next to ur ecu under the pass side capret or like
my last car had it under the carpet under pass seat. u had to take the seat out to mess with it
