MPFI swap running rich
Old Jun 16, 2006 | 11:13 AM
nappyroots827's Avatar
Default MPFI swap running rich
has anyone ever had this problem, ive done the mpfi swap, running a pm6 ecu, stock si injectors, brand new si dizzy, z6 mani, oem map sensor, everything pretty much stock, or oem si stuff...but my autometer a/f guage is showing im runnin really rich, like almost off the guage, and my gas mileage is around 28 mpg, with a good bit of highway
Old Jun 16, 2006 | 12:24 PM
ham's Avatar
ham
Default Re: MPFI swap running rich (nappyroots827)
pm6 makes it run a little rich, and i wouldnt trust your autometer a/f gauge. 28mpg is the lowest i got with mine, usually it was a little higher. it slightly worsened from dpfi mileage.
little things that could make a big difference: do you have an adjustable FPR? your fuel pressure could be off. whats your timing set at? IMO it doesnt seem like you have a serious problem, i would check those minor things and say its good.
Old Jun 16, 2006 | 12:39 PM
Default Re: MPFI swap running rich (ham)
i do have an adjustable fpr, but its at 32 psi. which is lower than stock actually, i turned it down a bit to adjust for the even richer condition i had before i turned it down...I heard the pm6 was a bit of a fuel saver tho, thats why i went from a pr4 back to the pm6
Old Jun 16, 2006 | 12:40 PM
EF9ZC's Avatar
thought 28 was stock correct me if im wrong but i got over 35 mpg with dohc zc and 32 with mini me zc was with dx tranny and mini was with si
Old Jun 16, 2006 | 01:13 PM
ham's Avatar
ham
try putting the stock FPR on there and see what happens. alot of fuel pressure gauges are bogus.
Old Jun 16, 2006 | 01:43 PM
i tried that a while back and it made it worse, so i think my guage is right...I mean soon here im gonna be putting in my pr4 which i chipped and made a basemap with turboedit so im gonna try and just compensate for it that way, but i would still like to know what is causing it
Old Jun 16, 2006 | 02:18 PM
ham's Avatar
ham
timing?
Old Jun 16, 2006 | 05:00 PM
just a tad advanced
90jdmcrxdude
May 20, 2006 11:03 AM
redlseg
12
Aug 12, 2005 04:44 AM
quicksol95
Feb 25, 2005 09:22 AM
01IntegraSE
Feb 4, 2003 06:05 PM
