4th gen vss
ok thanks that worked cause i was tryna find a thread and i couldnt,now my problem is this, my check engine is on throwing the 17 code (vss) and the D4 light is throwing the same code. this all happend after it rained last week. everything shifts good the only thing my speedometer is not working,yesturday morning everything started up right and everything was functioning right, after i was on the highway for a few mins the same problemm came back, so what could it be ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paysos »</TD></TR><TR><TD CLASS="quote">ok thanks that worked cause i was tryna find a thread and i couldnt,now my problem is this, my check engine is on throwing the 17 code (vss) and the D4 light is throwing the same code. this all happend after it rained last week. everything shifts good the only thing my speedometer is not working,yesturday morning everything started up right and everything was functioning right, after i was on the highway for a few mins the same problemm came back, so what could it be ??</TD></TR></TABLE>
you say everything shifts fine...if you have a manual then the VSS will not effect shifting, it only effects shifting if you have an automatic tranny because the ECU reads how fast the car is going and knows when to shift, if you car is reading 0 MPH/kph then it wont shift...
check to see if it is plugged in. my plug came loose, and I bought a VSS, got ready to change it, and found the plug had come undone. its about a 30 minute job to change it. 2 hose clamps, 2 bolts(i think, cant remmber) and 1 plug...just king of hard to get to. I think I had to undo my shifter cables to change it out, but just check the plug first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paysos »</TD></TR><TR><TD CLASS="quote">its an auto and been driving it without any problems besides the speedometer not working, can it be something else??</TD></TR></TABLE>
yeah, it might be something else. are you throwing a code? if your VSS isnt functioning, then your car would have erratic shifting.
the only thing i notice was that when i push it it was taking a little longer to shift like if it was slipping and on the highway to day i thought it was in 4th but it was in third, imma try and get behind it tomorrow to get a look at it
