can i take the window trim off?
Old Jun 16, 2006 | 07:41 AM
rewerbcrx's Avatar
Default can i take the window trim off?
can i take the rear quarter glass window trim off and put it back on without a problem?
Old Jun 16, 2006 | 07:51 AM
harmonator84's Avatar
Default Re: can i take the window trim off? (rewerbcrx)
yes it is very easy...just get a haynes manual, it will show you what all is there to take apart.
Old Jun 16, 2006 | 07:52 AM
rewerbcrx's Avatar
Default Re: can i take the window trim off? (harmonator84)
i can get it off.. i just wanna make sure i can reuse it
Old Jun 18, 2006 | 03:04 PM
rewerbcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">i can get it off.. i just wanna make sure i can reuse it
bump
Old Jun 18, 2006 | 03:14 PM
Crx Jimmy's Avatar
it fits under the glass, its almost impossible to remove without destroying. they are most likely faded and cracking so take the glass out and put new ones on, I did when I painted my car I think they were about $40, new get some new ones!
Old Jun 19, 2006 | 08:56 AM
rewerbcrx's Avatar
Default Re: can i take the window trim off? (Crx Jimmy)
in the uarter glass...? it seem to start to come out wicked easy
Old Jun 19, 2006 | 08:57 AM
civicandy's Avatar
the plastic part doesn't go behind the glass. if you go slow you can remove them and replace them. like all honda interior pieces, you need to be carful not to break the clips
Old Jun 20, 2006 | 06:04 AM
rewerbcrx's Avatar
Default Re: can i take the window trim off? (civicandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicandy &raquo;</TD></TR><TR><TD CLASS="quote">the plastic part doesn't go behind the glass. if you go slow you can remove them and replace them. like all honda interior pieces, you need to be carful not to break the clips</TD></TR></TABLE>
i mean the outside trim on the quarter glass
Old May 18, 2007 | 04:46 PM
jnuanz382's Avatar
can you post some pictures and steps thanks..
Old May 18, 2007 | 05:42 PM
Crx Jimmy's Avatar
Default Re: can i take the window trim off? (jnuanz382)
damn back from the dead. As I stated earlier I did not find a way to get them out without destroying them. this pertains to the crx only. these go over the glass then the trim and glass get glued in, good luck
Old May 18, 2007 | 06:06 PM
RockinthEFhatch's Avatar
Yo Jimmy, where did you buy the seals from?
Old May 18, 2007 | 07:02 PM
Crx Jimmy's Avatar
Default Re: can i take the window trim off? (RockinthEFhatch)
Honda, FTW they come in a nice minty fresh bag and cost like $40
crex23
May 6, 2011 02:58 AM
JDM_EK_JOE
Jun 23, 2008 07:41 PM
JjuuN R
Oct 6, 2007 03:32 PM
WhiteOnRice
Jul 6, 2007 03:53 PM
EGgwhite
Mar 20, 2005 07:10 AM
