HELP!the coolant fan can"t stop!
Old Jun 16, 2006 | 05:33 AM
but's Avatar
but
Default HELP!the coolant fan can"t stop!
the coolant fan allways run @ my 94 CD5 even turn off A/C and low engine temp!
anyone can help me!
Old Jun 16, 2006 | 05:35 AM
Ross 2.0's Avatar
In a Junkyard near you.
So this car is stock and nothing has been meesed with on the system? And no matter what the fans runs with the ignition on or off?
Old Jun 16, 2006 | 05:42 AM
but's Avatar
but
Default Re: (MooGoCow3)
ignition on =>fan on even turn off A/C and low engine temp!
ignition off=>fan off!
Old Jun 16, 2006 | 08:52 AM
JimBlake's Avatar
Default Re: (but)
There's a fan switch on the thermostat housing (follow the lower radiator hose). Unplug that & see whether it turns off. If that turns it off, you need a new switch.
Old Jun 16, 2006 | 10:07 AM
but's Avatar
but
Default Re: (JimBlake)
OK! i try it later ! thanks!
Old Jun 16, 2006 | 05:04 PM
crxklrlude's Avatar
Default Re: (but)
also check your relay maybe stuffed check with a multimeter for closed circuit when unpluged if 4 pin two will have continuity with a high risistance and two will be open circuit when unpluged
Old Jun 16, 2006 | 05:57 PM
someone else's Avatar
It Wasn't Me!
Default Re: (crxklrlude)
Take the handle of a screwdriver and tap on the fan relay when they are running too long. If they shut off the relay is bad. I see it on 94-95s all the time in the summer.
Old Jun 23, 2006 | 12:02 AM
PnX-R's Avatar
Default Re: HELP!the coolant fan can"t stop! (but)
94 accord? well from what I remember, there's a timer for the fan and there's two temp switches. what I usually try first is swap the relay with the one next to it. if that doesn't work, i usually start by disconnecting the two temp switches. i go with the one closet to the upper radiator hose. if disconnecting it shuts it off, replace that switch.
Old Jun 23, 2006 | 03:49 AM
JimBlake's Avatar
Default Re: HELP!the coolant fan can"t stop! (PnX-R)
The fan switch in the thermostat housing is responsible for switching the fan while the engine's running. The other one is responsible for switching the fan after you turn off the engine.
84dime
34
May 10, 2024 02:07 PM
lhd dc2
22
Apr 21, 2010 08:26 AM
dog70
Jun 9, 2006 04:27 AM
yangtech
Oct 6, 2005 06:44 PM
ATS*Mark
Dec 9, 2003 11:08 PM
