Cutting my CAI
Old Jun 15, 2006 | 10:55 PM
lude1888's Avatar
Default Cutting my CAI
I have a 93 si with an o.g. AEM cold air which I have grown attached to it. The problem is that when I had a mechanic work on my car he installed the cold air back on to rub on the side walls where it dips down into the bumber so it put a slit in it. Now should I fix the hole which is about 2 inches long or cut the damn thing and make it a short ram. Any input on preference between the two please state.
Old Jun 16, 2006 | 12:07 AM
Leo C's Avatar
Night Owl
Default Re: Cutting my CAI (lude1888)
i would say cut it where the slit is. either option would be better tha what you have now
Old Jun 16, 2006 | 12:08 AM
sparkx888's Avatar
I agree
Old Jun 16, 2006 | 12:24 AM
lude1888's Avatar
Default Re: Cutting my CAI (shutupnskate)
I guess my question is by preference. Should I try and fix the cold air or would I totally be better off with a CAI
Old Jun 16, 2006 | 12:29 AM
Leo C's Avatar
Night Owl
if there is a huge gash in the pipe then ghetto-rigging it ( fixing it w/ duct tape, whatever) will cause turbulence in the air flowing throuhg the intake. ghetto-rigging it will most likely diminish any performance gains from it being a CAI
Old Jun 16, 2006 | 12:32 AM
lude1888's Avatar
yeah, I think thats what I'll do, but what about the idea of putting a bypass valve there since it is a CAI.
Old Jun 16, 2006 | 12:38 AM
Leo C's Avatar
Night Owl
hmm good idea bypass valve ftw
just make sure that you cut the pipe nice and even above and below where the slit is.. a hacksaw should do the trick
Old Jun 16, 2006 | 12:46 AM
lude1888's Avatar
Just one more question, do you know what size bypass should I get. Do you think the 2.5'' will work?'
Old Jun 16, 2006 | 03:10 AM
prelude1897's Avatar
I had a hole in my CAI, and I just put tape around it. Works just fine
Old Jun 16, 2006 | 04:35 AM
maks's Avatar
Default Re: Cutting my CAI (prelude1897)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">I had a hole in my CAI, and I just put tape around it. Works just fine </TD></TR></TABLE>
A properly taped up slit will not disturb air flow as much as a Bypass Valve. You can always seal it up (as long as you can get your hand in there).
A CAI with a slit will NOT bring you down to the same performance as the stock setup.
I would put a bypass valve in for safety though...
Old Jun 16, 2006 | 06:27 AM
sharkcohen's Avatar
Default Re: Cutting my CAI (maks)
Make it a short ram. There's plenty of cool air flowing into the engine compartment while driving.
Old Jun 16, 2006 | 03:35 PM
Silver Surfer's Avatar
make the mechanic buy you a new one ftw
Old Jun 16, 2006 | 04:04 PM
lude1888's Avatar
Default Re: (Silver Surfer)
Its all good I took it off and the cuts didn't dig into the intake it just sliced it pretty close to too deep. Thanks anyway everyone.
Rs-xtacy
May 17, 2007 06:29 AM
Wolfwood
Jul 27, 2005 04:02 AM
lude_si_95
Oct 9, 2003 07:42 AM
gleinz
32
Oct 16, 2002 12:05 PM
E. Honda
Sep 18, 2002 06:14 AM
