93 d16z into 91 hatch swap ?s
Old Jun 15, 2006 | 07:21 PM
2gen_tegs_rule's Avatar
Default 93 d16z into 91 hatch swap ?s
looking at getting 91 dx for cheap but i know they aint got no power under the hood.. buddies got d16z out of a 93 si .. want to swap it all over to the 91 i know it aint that hard but what harness do i need , better to switch to obd1 or stay obd0, can i switch to a hydro or better finding cable.. help me oout...
Old Jun 15, 2006 | 08:57 PM
court's Avatar
25 Year Member
Default Re: 93 d16z into 91 hatch swap ?s (2gen_tegs_rule)
search under crx/ef y0
dpfi to mpfi, d16z6, sohc vtec
Old Jun 16, 2006 | 01:48 AM
HiProfile's Avatar
You will need to take a mpfi hanress (crx/civic HF, EX, Si) and add various sensor connections in the right places, or hack up your stock DX harness, which is above most people's experience level. The tranny has to stay cable, unless you want to do a shitload of welding for brackets and bend up hydro tubing or make some conversion lever/brackets like HASport's b-series kit.
Its better to go obd1, since there isn't any obd0 d-series vtec ecu, the closest is the jdm pr3 (b16). Otherwise you use an Si/EX ecu with a switch, and that doesn't work the best for power.
Old Jun 16, 2006 | 05:21 AM
whiteturbohatch's Avatar
HiProfile is right...if you cant solder....dont attempt this swap. If you can solder, or know someone who can and got the motor for cheap, its worth the effort.
Travis
Old Jun 16, 2006 | 01:57 PM
Default Re: 93 d16z into 91 hatch swap ?s (whiteturbohatch)
well i can get the eng trans ecu harness stg 1 cam and aem gear for 600.. but i only plan on running it till winter and by then i should have to money to do a complete sir front clip swap from rhd to bumper.. so i was looking for some power for a couple summer months.. so would you say that the d16 is worth it or just save the money.. and for the swap has anyone done the rhd swap and whats all instore??
Jroman16
Sep 13, 2015 08:43 PM
ATL-EF squad
May 7, 2008 09:15 PM
Rexwhippin33
Apr 3, 2008 02:50 PM
civicracer94
May 15, 2005 01:23 AM
hondahybrids
Jul 8, 2004 02:42 PM
