tranny problems
Just put ys1 tranny on my b16a with the new stock clutch kit for the 92-93 integra. Everything bolted up but now my car won't shift into any gears. With the car off the car still shifts through the gears but once on, it makes like a grinding rubbing sound. I installed the clutch with the clutch side towards the flywheel, I also fully adjusted the clutch cable back and forth and still no luck. Any help will be appreiciated, thanks
stupid question, did you put fluid in the trans and are you sure the syncros are gone. and how did the TO bearing look and is it installed correctly? just throwing ideas out there
sychromesh tranny fluid is in the transmission 2.3 liters of it, throwout bearing is brand new and installed correctly, I believe the throwout bearing can only go in one way, would you be able to shift throw the gears with the engine off if the sychros were gone, just wondering, thanks
NegativeXero
Nov 15, 2007 12:39 PM
oem_dc2
Jul 14, 2005 11:22 AM
