Installing coilovers
you dont need one... its pretty basic. Take the rim off..and just spend a couple minutes and look at what you would have to unbolt. You may need a spring compressor just to get the stock springs out.
I used this website for the fronts http://www.ntpog.org/mods/fift...shtml
and this website for the rears
http://www.geocities.com/joon525/Teins/Tein.htm
Well, if you're installing full coilovers then you just take out the stock suspension as one piece and put the coilover setup in. But if it's something like a coilover sleeve that you have to install over a seperate shock, then you will need a spring compressor......just depends.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">Well, if you're installing full coilovers then you just take out the stock suspension as one piece and put the coilover setup in. But if it's something like a coilover sleeve that you have to install over a seperate shock, then you will need a spring compressor......just depends.</TD></TR></TABLE>
stole the words right outta my mouf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">Well, if you're installing fullif it's something like a coilover sleeve that you have to install over a seperate shock, then you will need a spring compressor......just depends.</TD></TR></TABLE>
I dont even bother w/ a compressor. I just stand on the shock and spring and then undo the top hat nut. You get a good rush right before it pops, but nutin really comes flying off.
Kyles ej1
15
Sep 25, 2004 07:33 PM
Accord98
Jul 25, 2003 11:20 PM
2001, 4th, coilover, coilovers, compressor, install, installing, prelude, rent, sleeves, springs, stock, suspension, tein, thread
