should i port and polish the head of my b18
Old Jun 15, 2006 | 01:53 PM
lrcrx90's Avatar
Default should i port and polish the head of my b18
iwas considering porting and polishing the head and also shave it. would this help with adding more power
Old Jun 15, 2006 | 02:07 PM
lrcrx90's Avatar
has anybody done this before and is it worth it.
Old Jun 15, 2006 | 03:03 PM
lrcrx90's Avatar
so i guess u guys don't have all the answers
Old Jun 15, 2006 | 03:18 PM
jdmcrx90's Avatar
i would not waste my money on that.
Old Jun 15, 2006 | 03:19 PM
Suck my DX's Avatar
Default Re: (lrcrx90)
i shave my head
Old Jun 15, 2006 | 06:39 PM
nappyroots827's Avatar
Default Re: (Suck my DX)
No offense, but if your asking this question, your better off not doing any of this yourself, just take ure **** to a machine shop and ask them what would be the best, cuz im sure they have done a b18 before and know what helps them
Old Jun 15, 2006 | 06:54 PM
DEEGORILLA06's Avatar
Default Re: (nappyroots827)
that was funny.
Old Jun 15, 2006 | 07:07 PM
sic944t's Avatar
Default Re: (DEEGORILLA06)
also research this topic a little more there are endless threads on here devoted to the topic also Vtec versus non Vtec different concepts and principles in terms of the work you would do and yea .....
if this is a serious question then you shouldnt do it yourself ..
Old Jun 15, 2006 | 08:22 PM
philkehn's Avatar
for the power that you get out of it, its not worth your money you think it would probably take a shop about 24-48 hours of work at 40 bucks an hour at that cost just buy you a new engine and bigger engine
Old Jun 17, 2006 | 10:05 AM
La EF-8's Avatar
i port and polished my b16 head and i couldnt tell a huge difference
Old Jun 18, 2006 | 10:36 AM
Default Re: (La EF-8)
thats because a b16 head is ona of the best stock flowing heads honda makes, your not gonna do too much better
Old Jun 18, 2006 | 11:20 AM
Bjorn20's Avatar
you can get the kit for port and polishing for $50, but yes it takes a lot of time to do it (15-20 hours).
but im still sketchy on the whole concept behind it.
that if you read this guys site.... http://mototuneusa.com it sais in there that pnp your head (making the ports bigger for more air flow) will actually make you lose power rather than gain in. he also sais that making your ports smaller will gain more hp because the oxygen traveling in is going at a higher velocity into the combustion chamber because it has got less space to squeeze through.
but again im not sure on the whole pnp idea, more oxygen doesnt neccessarily mean more power.
Old Jun 18, 2006 | 12:25 PM
Default Re: (Bjorn20)
thats a load of ****. the reason ports are the size they are from factory is because, first of all the smaller ports allow for more metal material and less likely to crack and break, also, it designed for optimal power while mantaining optimal fuel efficiency, so you have to sacrifice power for fuel efficiency. A bigger port will give power gains to a degree. BUT there is such thing as too big. You want to make the perfect balance between port size and velocity. Your best bet for something like this is to take your head a shop with a flow bench, they will be able to find out the most optimal port size for your application.
Old Jun 18, 2006 | 12:34 PM
Bjorn20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nappyroots827 &raquo;</TD></TR><TR><TD CLASS="quote">thats a load of ****. the reason ports are the size they are from factory is because, first of all the smaller ports allow for more metal material and less likely to crack and break, also, it designed for optimal power while mantaining optimal fuel efficiency, so you have to sacrifice power for fuel efficiency. A bigger port will give power gains to a degree. BUT there is such thing as too big. You want to make the perfect balance between port size and velocity. Your best bet for something like this is to take your head a shop with a flow bench, they will be able to find out the most optimal port size for your application.</TD></TR></TABLE>
expletive a flowbench, those results measure **** thats not even important, but i still dont know what to believe on the pnp idea. guess ill have to just trial and error it myself
Old Jun 18, 2006 | 01:41 PM
how does it measure something thats not important? but yea, go ahead and try it, if you do it right, your not gonna lose horsepower, but if you just enlarge the whole port and not the right areas, then yea, you probably will
cibao2ner
35
Mar 14, 2011 10:20 AM
amnbassist
12
Aug 25, 2010 02:56 PM
Blazen_angles
11
Dec 9, 2007 09:21 AM
AndrePerras
Dec 22, 2006 08:51 PM
SQ is the SQUAD
Oct 20, 2005 06:10 PM
