hissing noise when i turn off my gsr
Old Jun 15, 2006 | 08:54 AM
h-townteg's Avatar
Default hissing noise when i turn off my gsr
when i turn off my stock gsr. theres a hissing noise coming from inside of the intake manifold. it only does it for about 2 seconds. it sound like when water hits hot metal. but i checked everything, and everything is ok. i'm also having problems with my butterfly valve i dont know if its related to this problem. but heres my other thread.
https://honda-tech.com/zerothread/1660588
Old Jun 15, 2006 | 09:12 AM
Azn Kenny's Avatar
Do you have an intake?
It's probably your intake.
Old Jun 15, 2006 | 09:18 AM
h-townteg's Avatar
Default Re: (LS-N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS-N &raquo;</TD></TR><TR><TD CLASS="quote">Do you have an intake?
It's probably your intake.</TD></TR></TABLE>
yea i got a intake. but after that sound the intake makes after u turn the car off like a suction noise it, makes this hissing noise
Old Jun 15, 2006 | 09:34 AM
Azn Kenny's Avatar
Completely normal. I love that noise.
Old Jun 15, 2006 | 09:39 AM
kchungb17a's Avatar
Default Re: (LS-N)
The pressure inside the intake manifold which ideally is about 19 inches of mercury (about 9.33 psi) below atmospheric pressure while you are idling. When you turn the engine off, all the air outside your intake manifold is rushing in through your filter to equalize the pressure. This is the noise you are hearing. Perfectly normal and yes, kinda cool sounding.
Old Jun 15, 2006 | 10:47 AM
h-townteg's Avatar
Default Re: (kchungb17a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kchungb17a &raquo;</TD></TR><TR><TD CLASS="quote">The pressure inside the intake manifold which ideally is about 19 inches of mercury (about 9.33 psi) below atmospheric pressure while you are idling. When you turn the engine off, all the air outside your intake manifold is rushing in through your filter to equalize the pressure. This is the noise you are hearing. Perfectly normal and yes, kinda cool sounding.</TD></TR></TABLE>
yea i know that sound its been on all my cars i've had with intakes. but after that sound theres a sound like water hitting hot metal. like a sizzling sound
Old Jun 15, 2006 | 10:49 AM
1337whp's Avatar
Default Re: (LS-N)
its normal, mine does it its like shhhhhhhhhhhhhhhhhhhhhhh.....
Old Jun 15, 2006 | 10:57 AM
99teg's Avatar
Default Re: (1337whp)
lol, i know that shhhhh sound is normal all my cars with intakes have done it. my brother has the same set-up on his integra but his is a 94 gsr. but it doesnt make that sizzling noise. i dont know maybe it has something to do with my secondary butterfly valves. i'll try to figure it out. thanks though u guys
potatointegra01
Mar 14, 2016 12:07 AM
DSBP1
18
Jul 7, 2007 07:51 PM
aznxpyroboi
Jun 1, 2007 08:21 PM
Puffwheat
Feb 13, 2004 09:59 PM
tuco_ruiz
Jun 23, 2002 11:40 AM
