Junkyard HID.....can I do it? 95 civic....
Old Apr 16, 2002 | 01:37 PM
Big Red Jim's Avatar
Default Junkyard HID.....can I do it? 95 civic....
As the topic says, I'd like to do a junkyard HID setup on my '95 Civic EX. I know I need ballasts and bulbs, but will any of them do from any car equppied with HID's? Would I be best-suited looking for a wrecked Acura to take them from? And if I do find one, are HID's taken frequently?
Old Apr 16, 2002 | 02:14 PM
gohandbz's Avatar
Default Re: Junkyard HID.....can I do it? 95 civic.... (Big Red Jim)
Well if you can find it its doable but remember u will lose your high beam. Some ballast need external igniters so make sure u got everything. I did this setup on my 95 civic coupe with audi ballast and hid. Good luck with ur setup.
Old Apr 16, 2002 | 02:39 PM
poison's Avatar
Default Re: Junkyard HID.....can I do it? 95 civic.... (gohandbz)
o lord, that must look awesome. u have those in projectors right?
it would look strange with oem headlights, or just the thought makes me think it'd look strange.
Old Apr 17, 2002 | 09:47 AM
gohandbz's Avatar
Default Re: Junkyard HID.....can I do it? 95 civic.... (poison)
actually its not in projectors. I have D2R bulbs in my stock housing. The housing on civic projectors are too small to fit the hids in there so I stuck with stock headlights. Lighting is great (much better than with halogen bulbs) and its not glaring since i had turned it down.
Old Apr 17, 2002 | 10:05 AM
Plan B's Avatar
I'd like to have HID also.
Old Apr 17, 2002 | 06:46 PM
poison's Avatar
ya but you can modify the projector insert, (its only big enough for h3, if not h1), lil tiny h lights, it's possible to modify and do mounting on it so the HID will fit.
i personally think it'd look better in projectors like audi's and BMW's have.
I know alot of BMW's and Acura's like RL and CL have hid with housing, i like audi's with projectors and think it'd look better with that ;x
what bulbs are mainly used for HID's? cuz i want to do hid conversion in mine and i have projectors
[Modified by poison, 8:47 PM 4/17/2002]
Old Apr 17, 2002 | 06:55 PM
JRSC EM1's Avatar
Ive got HID's from a 01 GS400 in my '00 Si. It was easy and the lights are unreal. You do lose your high beams, but the HID's are way brighter than my high beams ever were even with PIAA superwhites. None of my cars will ever use standard bulbs again.
Old Apr 17, 2002 | 08:07 PM
gohandbz's Avatar
My real big concern with the projector was that im afraid the housing wont be long enough for the hid bulb. Although im not really sure cause i never actually had projectors before. Instead i plan to get some audi hid projectors and fit it into my stock headlight housing. That way ill have the correct beam pattern.
philly10psi
Jun 2, 2011 11:55 PM
Vt3c_eg
23
Apr 4, 2007 03:55 PM
NitroStickers
Sep 15, 2005 06:59 AM
ITR1071
May 19, 2003 02:19 PM
