i have some cut wires (under my ignition cylinder) where do they go??
whats goin on? as some may know i've been havin trouble gettin my '92 gs to start....well when i was under my steering wheel to check the main relay, i noticed 3 cut wires(all in the same"loom") just under the ignition cylinder (where the key goe's)
the 3 wires were:
- white w/red stripe
- white w/blue stripe
- white w/yell stripe
where do they go/ what do they do?? (this could be a reason why my car has trouble starting)
the 3 wires were:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote">ttt</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akstunt600 »</TD></TR><TR><TD CLASS="quote">are they thick? by the description they sound like the main ignition wires.
maybe it was wired for a turbo timer???</TD></TR></TABLE>id say about14-18 gauge so pretty thin and they look to be "stock" or original wires and there connected to the ignition right under the key hole......im supprised the car has been starting/running this long
is your car 5 spd?
it sounds like the steering colums was automatic
it has a solenoid that will only release the key when the car is in the parked position.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Last For One »</TD></TR><TR><TD CLASS="quote">pic </TD></TR></TABLE>sorry i suc at the web...i dont know how to post pics
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks »</TD></TR><TR><TD CLASS="quote">is your car 5 spd?
</TD></TR></TABLE> yes the car is 5speed(i should have mentioned that) do you know of anyother ways to check and see if it was from an auto?? im very curious to find out what these wires are for (thats just the start, i have some other cut wires under my steering column
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks »</TD></TR><TR><TD CLASS="quote">is your car 5 spd?it sounds like the steering colums was automatic
this is a pic of a auto key ignition switch.
you see the little rectangle on top left that is the solenoid that releases
locks in the key
locks in the key
</TD></TR></TABLE>wow thanks for the help!!! that is where the wires are coming from on my ignition, so i guess it was from an auto. thanks for the help
locks in the key
