Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
?????? about legend 87 codes
Old Jun 15, 2006 | 06:53 AM
si90rex's Avatar
Default ?????? about legend 87 codes
does a acura legend 87 i think have a way of checking codes a friend of mine has one and i wont start but it turns over and the only time it does try the start, the mpgfi light in the dash come on and it will start. whats the deal can anyone help is a legend obdo of what and where the ecu at. i look under the carpet. thanks for any help.
Old Jun 15, 2006 | 09:49 PM
ikeray's Avatar
Default Re: ?????? about legend 87 codes (si90rex)
if he has a sedan, the ecu is located under the passenger seat. under the driver seat is the tcu incase you ever need that. as far as turning over and not starting, can be a number of things including gas and spark. when you first turn the key to ON but not starting it, listen for a click to come from the rear of the car, that is the fuel pump clicking on (via the main relay). next, check your plugs to see if they are getting spark. 9 times out of 10 its the main relay that goes bad (located under the dash by the fuse panel on the driver's side). if it does this to me, i typically give the dash repeative swift kicks (not too hard, dont want to break anything) while turning the key, and it starts for me.
as far as code meaning:
1986-1990 Legend (G1)
Code # Explanation
1 Front Oxygen Sensor
2 Rear Oxygen Sensor
3 Manifold Absolute Pressure Sensor
5 Manifold Absolute Pressure Sensor
4 Crank Angle Sensor
6 Coolant Temperature Sensor
7 Throttle Angle Sensor
8 Top-Dead-Center Position Sensor
9 Number 1 Cylinder Piston Position
10 Intake Temperature Sensor
12 E.G.R. System
13 Atmospheric Pressure Sensor
14 Electronic Idle Control Module
15 Ignition Output Signal
17 Vehicle Speed Sensor
18 Ignition Timing Adjustment
pulled from the G1 faq page located here:
http://acura-legend.com/vbulle...83445
Old Jun 16, 2006 | 05:22 AM
si90rex's Avatar
Default Re: ?????? about legend 87 codes (ikeray)
thanks this will help out alot, and has far code go thats what i was looking for. i have 90 crx b16a so i'm not used to the older style legends. thank alot
olschool92
Jul 25, 2011 02:38 PM
tmrtwo
Jun 19, 2009 02:51 PM
NazVil86
Oct 10, 2006 06:44 PM
Adam West
Jul 27, 2005 07:16 AM
Red_Si
13
May 7, 2003 03:21 AM
