B16a Y1 haftshatf and axle problems??????
ok i finished my swap and im having issue turning but a friend of mine said that the axle is bound up and the axle in a jdm crx are shorter that a 90-93 integra. so is this true. if so do i need a halfshaft out of a 90-93 integra ls. or is there some way of shorting the one axle. both brand axle for a 90- integra if any one can help i would be greatful.
its jdm B16a w/lsd in a 90crx si
thanks
thanks
depending on the intermediate shaft that came with the swap, the JDM crx intermediate shaft is longer. IF you switch to a 90-93 integra intermediate shaft it will fix your problem.
that what i figured but i need to find the intermediate i was at the junkyard yestard day and there wasn't any 90-93 integras with motors every one has already toke the ls as a swap. i need a parts finder i also was told if i use a 94 gsr ls and use the axle and intermediate shaft it should work. i don't know about that though.
aojtin
Mar 6, 2009 12:26 PM
iridebiketrials
Jun 10, 2004 05:22 AM
