Snap-On YA205A Mig Welder problems
Old Jun 14, 2006 | 11:37 PM
Stoich EG2's Avatar
Default Snap-On YA205A Mig Welder problems
I've had this welder for a very long time.
Everytime i try to use it, i press the trigger and sometimes nothing happens. there is a ground. Sometimes it will let out wire, and sometimes it won't.
any ideas?
Old Jun 15, 2006 | 05:37 AM
dopefeen's Avatar
Default Re: Snap-On YA205A Mig Welder problems (ADVAN EG2)
check ur dry rollers....the things that feed the wire into the hose. do they work? sometimes u need to take it apart and put it back...or it could be the pressure?
Old Jun 15, 2006 | 09:46 AM
Stoich EG2's Avatar
Default Re: Snap-On YA205A Mig Welder problems (dopefeen)
i'll check that out today
Old Jun 15, 2006 | 10:15 AM
k24em2's Avatar
Call the Snap on guy?
Old Jun 15, 2006 | 11:34 AM
TeamNextGenChris's Avatar
i've had a YA212 forever now.
it's very sensitive to roller adjustment.make sure the bearings roll easily.try adjusting the tension.
open the side panel up and watch the wire and feed mechanism as you squeeze the trigger to make sure this is your problem.
chris
Old Jun 19, 2006 | 08:10 PM
Stoich EG2's Avatar
Default Re: Snap-On YA205A Mig Welder problems (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">i've had a YA212 forever now.
chris</TD></TR></TABLE>
thanks a lot sir, the wire feed was my problem the whole time
another problem was i had the line going to the gun too bent
Old Jun 20, 2006 | 11:27 AM
eddie_ek's Avatar
Make sure thr hose is not kinked mine had that problem and check the tip of the gun sometimes they get to hot and jam up goodluck
dc7
May 29, 2008 12:11 AM
2SlowDC
Audio / Security / Video
Apr 15, 2006 08:55 AM
Cheeech
Oct 28, 2005 11:29 PM
flip1199
Jul 29, 2005 02:48 PM
