B16 Swapped CRX wont start and I have a question
Old Jun 14, 2006 | 11:25 PM
Trevor's Avatar
Default B16 Swapped CRX wont start and I have a question
OK the car has been sitting for about ten months now.
I think I have it sold and now it wont start. I know the old gas may be part of the problem but here is my other question.
When the key is turned to the on position I sould hear the fuel pump come on right? It does not. I am just trying to figure out what would cause the fuel pump to fail since the car has just been sitting. It will turn over but wont fire.
Any help would be great.
Sorry if I sound like an idiot, its late and I am tired.
Oh its a 88 CRX DX with a jdm b16a swap and pr3 ecu
Old Jun 15, 2006 | 12:16 AM
2poor2tune's Avatar
i have the same problem and have been told many times to replace the main relay. the little box that clicks under the dash on the left wall of the car. turn to acc. then listen for a click. then you have it
Old Jun 15, 2006 | 01:14 AM
jdmcrx90's Avatar
how charged is your battery?? if its fully charged check your main relay
Old Jun 15, 2006 | 11:12 AM
Trevor's Avatar
Default Re: (jdmcrx90)
The battery is nearly dead, but I have jumper cables conected to my accord.
I guess I will check the relay now. Should the relay click when the key is turned on?
Old Jun 30, 2006 | 12:20 AM
Trevor's Avatar
Default Re: (Trevor)
OK guy its not the relay. Still no fuel. Any other ideas?
Old Jun 30, 2006 | 04:47 AM
crxnj's Avatar
Are you getting spark atleast? if you dont know how to check---pop off one of the sparkplug wires from the distributor,,then hold the wire an 1" or so from the distributor and you should see spark when someone else tries to start it..
Also are you sure you're not getting fuel? you dont smell any around the fuel rail when you're cranking? Also the stock pump is pretty damn hard to hear to me if you have full interior..
Old Jun 30, 2006 | 11:42 AM
Trevor's Avatar
Default Re: (Mr.speaker)
I pulled the fuel line on the right side of the rail. Its bone dry. I have no rear interior and I am getting spark.
Old Jun 30, 2006 | 11:52 AM
b16civster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trevor &raquo;</TD></TR><TR><TD CLASS="quote">I pulled the fuel line on the right side of the rail. Its bone dry. I have no rear interior and I am getting spark.</TD></TR></TABLE>
it could be the pump But there is only one way to find out
Old Jun 30, 2006 | 02:33 PM
SomeDude56's Avatar
Default Re: B16 Swapped CRX wont start and I have a question (Trevor)
Find a schematic for the main relay and just use a piece of wire to jump the wires that control fuel delivery and if that gives you fuel its yuor main relay, and yes hondas have loud *** fuel pumps (to me and my crx at least) and I can clearly hear the "dunk" when I turn the key if Im looking ot hear it.
Old Jun 30, 2006 | 02:39 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: B16 Swapped CRX wont start and I have a question (SomeDude56)
Old Jun 30, 2006 | 02:47 PM
SomeDude56's Avatar
Default Re: B16 Swapped CRX wont start and I have a question (88DXCRX)
^^^^ I had a feeling youd come to the rescue in this thread
Old Jul 5, 2006 | 03:37 PM
Trevor's Avatar
OK so I tested my relay an thought that was the problem. Now I have a brand new one and the pump still is not getting power. What is next?
Old Jul 5, 2006 | 03:58 PM
88DXCRX's Avatar
First of all,Get a good hot battery in the car..
When you turn on the key,the check engine light should
come on,then go out in a few seconds..
If it does not,check fuse #14.. it provides power to the relay..
Old Jul 5, 2006 | 05:22 PM
Trevor's Avatar
Alright, that fuse was bad. I replaced it and now the relay clicks when I turn the key on. With a test light I can tell the fuel pump is getting power now but it still does not come on.
Old Jul 5, 2006 | 07:41 PM
Trevor's Avatar
up for some help please
Old Jul 5, 2006 | 11:22 PM
ALLMOTORCRX20's Avatar
If the relay clicks, it means its bad. Take it out and smell it, it might smell like its burned. I had the same problem in my EG. The relay would click and the car would just turn over and wouldnt start. Replaced the relay and it turned on.
Old Jul 6, 2006 | 05:38 AM
crx_88_si's Avatar
Default Re: B16 Swapped CRX wont start and I have a question (ALLMOTORCRX20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTORCRX20 &raquo;</TD></TR><TR><TD CLASS="quote">If the relay clicks, it means its bad. Take it out and smell it, it might smell like its burned. I had the same problem in my EG. The relay would click and the car would just turn over and wouldnt start. Replaced the relay and it turned on.</TD></TR></TABLE>
uhm, no. WHen you first turn the key to ON (to prime for fuel) it will click (the CEL comes on at this time too), then a few seconds later the CEL will go off and the relay will click again. this is all normal.
if it clicks like mad while cranking then its bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trevor &raquo;</TD></TR><TR><TD CLASS="quote">Alright, that fuse was bad. I replaced it and now the relay clicks when I turn the key on. With a test light I can tell the fuel pump is getting power now but it still does not come on.</TD></TR></TABLE>
ok, so the fuel pump is getting 12v but still not turning on?
hope these help you..
Old Jul 7, 2006 | 12:34 AM
Default Re: B16 Swapped CRX wont start and I have a question (crx_88_si)
If the relay clicks a lot while cranking, then its bad. That's what I meant, but i should have been more clear about it. Sorry bro
Old Jul 7, 2006 | 05:15 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTORCRX20 &raquo;</TD></TR><TR><TD CLASS="quote">If the relay clicks a lot while cranking, then its bad. That's what I meant, but i should have been more clear about it. Sorry bro</TD></TR></TABLE>
it can.. but it can also mean there's a ground missing / loose somewhere (most notable the thermo-stat ground).
Lightsped
Jan 15, 2009 10:12 PM
kacivic
Sep 23, 2008 11:44 AM
Tysnet
Feb 11, 2008 10:42 AM
Hugsnkisses01369
Aug 18, 2006 02:46 PM
91d15bvtec
Jun 28, 2005 01:42 PM
