5th gen headlight working/not working.
My buddy just got a 5th gen prelude and his right headlight doesn't light up sometimes. I was driving with him and it magically relit.
The bulb that isn't lighting is the main one near the top of the headlight, not the one in the corner of the headlight.
Is it a loose wire or is it the bulb?
check the connections to the bulb and be sure they're secured. It also sounds like you may just need to replace the bulb. Try swapping the high beam bulb with the low beam bulb and see if that helps
The same thing happened to me about two months ago and all I had to do was push the connector back into the bulb and it hasn't done it since. Make sure that the bulb is connected securley to the connector. I think when it happened to me the bulb just got wiggled out of the connector. It may not work but hey it's worth a try.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jesseunvoas »</TD></TR><TR><TD CLASS="quote">is right behind the headlight coming off the bulb pull the rubber cover off then pull the conector</TD></TR></TABLE>
Gotcha, and if's not the connector then it's the bulb?
