how safe is this?
Old Jun 14, 2006 | 09:35 PM
3.point.2's Avatar
Default how safe is this?
so i bent the bolt coming from my lower ball joint removing my axles. the nut wouldnt go back on. my dad wanted the car out of the garage so i cut off the bottom of the bolt that was mishapen and got the nut on. i couldnt torque the nut because once the nut got screwed on all the way the ball joint spun with it. theres also no room for me to drill a hole for a cotter pin. as of now im not driving the car because i dont want to deal with that nut falling off. i already have the new ball joint but i just dont have the time to replace it now. should i continue to not drive the car or do you guys think itll be ok?
at most the car will be driven for 20 miles until i have the ball joint replaced
Old Jun 14, 2006 | 09:37 PM
sohcvtec1995's Avatar
Default Re: how safe is this? (h23eg)
honestly if you have to ask yourself if its safe then it probably isnt. i wouldnt drive it.
Old Jun 14, 2006 | 09:38 PM
hatchi's Avatar
as long as the nut is in there threaded in it should be ok.
Old Jun 14, 2006 | 09:41 PM
3.point.2's Avatar
Default Re: how safe is this? (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">honestly if you have to ask yourself if its safe then it probably isnt. i wouldnt drive it.</TD></TR></TABLE>
well obviously its not safe enough to keep it that way, im just wondering if i should be worried about driving 2 minutes down the street if i have to.
Old Jun 14, 2006 | 09:45 PM
like i said o i wouldnt. i mena you already have the parts. would you rather risk it all falling apart and you nailing a wall? or another car? for something that would have taken u 15mins to repair?
Old Jun 14, 2006 | 09:50 PM
3.point.2's Avatar
Default Re: (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">like i said o i wouldnt. i mena you already have the parts. would you rather risk it all falling apart and you nailing a wall? or another car? for something that would have taken u 15mins to repair?</TD></TR></TABLE>
you can replace a ball joint in 15 minutes? id like to know how if thats true. im planning on having a shop put it in cause im tired of causing problems by fixing other ones. the shop is like a mile away.
Old Jun 14, 2006 | 10:00 PM
once you have taken aparta civic suspension as many times and on as many cars as i have. you learn how to do them fairly quick.
Old Jun 14, 2006 | 10:45 PM
plz turn off trial user's Avatar
**** dude if u have to go over 60 mph i wouldnt do it, id say 45mph is pushin it, dude 20 miles? wow man chance are u live out in the sticks, if u had to go to the grocery store or sumthin its cool. just do it takes a non expericanced guy 30-45 mins, when i used to intern at a shop it took me 30 mins i had no clue what i was doing
Old Jun 15, 2006 | 02:53 AM
john666's Avatar
dont drive it til its fixed.. my friend didnt take my advice in a simaliar case didnt drive it str8 to a shop.. i followed him home 15 miles away. then next morning he drove a block and the car dropped.
Old Jun 15, 2006 | 05:14 AM
hotimportcrx's Avatar
Default Re: how safe is this? (john666)
Imagine Trying to top out your car or racing it and that coming off ....Personally ive wouldnt drive it like that.
Old Jun 15, 2006 | 05:34 AM
dopefeen's Avatar
Default Re: how safe is this? (hotimportcrx)
i had done the same thing...the bolt was so rusted it snapped off, but to answer ur question its not safe to drive around in. to roll ur car out of the garage ok but not to drive...even if u have the nut on the bolt.
Old Jun 15, 2006 | 11:03 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
dont drive it because it would look retarded if it ever fail on you
Juans_MX3
42
Jul 10, 2021 04:38 PM
gRim06
Apr 21, 2007 09:01 PM
CRseXy
13
Jan 10, 2005 10:49 PM
brx017
31
May 2, 2004 04:01 PM
pikappaphi
14
Feb 6, 2004 09:15 AM
