Well I'm gonna install my clutch and flywheel.....
Old Apr 16, 2002 | 12:42 PM
Black R's Avatar
25 Year Member
Default Well I'm gonna install my clutch and flywheel.....
I was gonna get it done under warranty, since the stock clutch is starting to go...
But I honestly don't trust any dealer's with my car - and I always like to tq things to spec...
Any tips for me, since I've never done one on an itr before?
Do I need a clutch centering tool?
Any recommendations? I was thinking of dropping the tranny without draining the fluid too..... Err... I can't can I, b/c of the pulling of the axle...
Will this be a good time to put the ES motor mount inserts in too?
Wish me luck everyone!
Old Apr 16, 2002 | 12:47 PM
adam's Avatar
Default Re: Well I'm gonna install my clutch and flywheel..... (Black R)
make sure you have 2 jacks and at least 1 friend, the tranny is heavy. my friend and i used a jack to help lower and raise the tranny. the other jack goes under the motor to hold it up, since you'll be removing the rear and passenger side mounts. good time to install ES ones, yeah.
stock clutch? others should come with a centering tool.. although it isn't absolutely necessary, just makes it easier.
Old Apr 16, 2002 | 12:56 PM
MPH's Avatar
MPH
New User
Good luck because it's a bitch. What do you have to separate the lower ball joints? I didn't have a ball joint removal tool so I ended up busting the boots with a big *** fork. Don't forget you need something to stop the flywheel from turning when you loosen the flywheel bolts. You can make something that will work. Also flywheel bolts have 12 point heads. Clutch center tool will make things easier. That's all I can remember for now. Good luck
Old Apr 16, 2002 | 12:58 PM
B18CXr's Avatar
Default Re: Well I'm gonna install my clutch and flywheel..... (MPH)
1/2 inch drive brakerbar for the ball joints and thick flatblade screwdriver to hold the flywheel
Old Apr 16, 2002 | 01:00 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: Well I'm gonna install my clutch and flywheel..... (B18CXr)
Yep, that and normal sockets/tq wrench are all you need for this job. Ball joints can be dropped in seconds with one hand in use and the other hand putting a bottle/can of to your mouth.
Old Apr 16, 2002 | 02:47 PM
Black R's Avatar
25 Year Member
Default Re: Well I'm gonna install my clutch and flywheel..... (adam)
Thanks adam,
Sorry I should've mentioned that I'm installing the toda clutch and flywheel in this pic:
No, it didn't come with a centering tool..... But yes, I've dropped the tranny before (when I installed the final drive) and am intimately familiar with the process.
Old Apr 16, 2002 | 02:49 PM
pyromaster's Avatar
good luck kenE!
-jeff, who knows who he'll be callin' when it's time to replace his clutch
Old Apr 16, 2002 | 04:43 PM
Type R1's Avatar
Hey post pics and details when you finished the project. I'm thinking of doing my own clutch change and installation later on this summer. Any help would be great. Thanks.
Jim
Old Apr 16, 2002 | 04:58 PM
D's Avatar
D
jack, make sure he knows the easy way to separate those lower ball joints.
Old Apr 16, 2002 | 05:15 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Well I'm gonna install my clutch and flywheel..... (D)
that skateboard could be useful as a jack!!
Old Apr 16, 2002 | 05:23 PM
Misfit's Avatar
Default Re: Well I'm gonna install my clutch and flywheel..... (RealTypeR)
who is going to let me stop down and help me change out my clutch and flywheel in a couple of months?
Old Apr 16, 2002 | 06:07 PM
RexxyR's Avatar
Default Re: Well I'm gonna install my clutch and flywheel..... (MISFIT)
can I ask how many kilometers you have on your car now that ur clutch is needing replacement
Old Apr 16, 2002 | 06:15 PM
Willard's Avatar
Default Re: Well I'm gonna install my clutch and flywheel..... (RexxyR)
Ken has ~40,000K on is car... the recient modifications have stressed the stock unit a bit much.
Old Apr 16, 2002 | 07:54 PM
IN VTEC's Avatar
32mm socket for the hub nut, and a 12" extension for the lower starter bolt. Unless sombody knows a quicker way to remove it.
Old Apr 16, 2002 | 09:10 PM
Black R's Avatar
25 Year Member
I've got 12k miles on the car currently. I dunno how many km that is.....
But yes, the stocker has pretty much given up the ghost... Although I don't think it was made to take all the power my mods have thrown at it...
Good thing, cause as D would say: "it's a wear item."
And yes fellas, I've got a neat little trick to removing the lower ball joints... Involves one of those weirdo forks - no boot damage =
Old Apr 17, 2002 | 02:23 AM
Willard's Avatar
~20,000K
I thought you had ~25,000mi on your car...
Will
Old Apr 17, 2002 | 05:30 AM
Dr Pooface's Avatar
Yup.
Old Apr 17, 2002 | 06:02 AM
b00st-0wnz's Avatar
Default Re: Well I'm gonna install my clutch and flywheel..... (IN VTEC)
Do not remove the drive shaft from the hub assm. There is no reason to. Lower start bolt is a pity but using one of those ujoint socket things makes it a lot easier.
If you are using a fork at all then you don't have the "WTDR/ITR-NC-FL super easy to drink a beer, seperate ball joint and smoke a cig at the same time for 15-30 seconds" method.
Old Apr 17, 2002 | 06:23 AM
AssPenny's Avatar
Default Re: Well I'm gonna install my clutch and flywheel..... (FL n NC rock j00)
Its so much fun that I'll be doing mine, again (5th time dropping tranny), next weekend...
Few hints:
- Make sure you have a 2x4 and a saw to cut up pieces to use to drive the axels out of the tranny.
- Don't remove the shift linkage at the tranny, just leave it hanging (see pic below)
- To remove the ball joints:
1) Place the hack on the rotor hub and jack up
2) place the end of a 1/2" breaker bar or ratchet between the lca and the hub/spindel. It will wedge right in there where the ball joint is. (see pic below)
3) drop the the jack.
4) drink some beer
- Find some one that has a clutch alignment tool, or take your time when putting the pressure plate and clutch on.
- Put high temp grease on the shaft so the throw out bearing moves smoothly
- Have a friend, that tranny is heavy.
- Pick up 3 more of thouse bolts that hold the pressure plate to the flywheel, as you will need them (stock has 9, toda needs 12, or some combination like that)
See how we left the linkage on
Place end of wrench where the white circle is:
Old Apr 17, 2002 | 06:27 AM
AssPenny's Avatar
Default Re: Well I'm gonna install my clutch and flywheel..... (AssPenny)
Oh yea, don't forget to drain the tranny, or when you pull the axles you'll get a face full of fluid.
Also leave the axles in the hubs, since the lca is off (also remove the suspention fork that attaches fromt he shock to the lca), this will allow you to pull the axles out fo the tranny. Then just tie them up and out of the way.
[Modified by AssPenny, 10:27 AM 4/17/2002]
Old Apr 17, 2002 | 06:34 AM
Willard's Avatar
why are you going to let the 'trick' out to the others?
Old Apr 17, 2002 | 06:41 AM
stRtypR25's Avatar
Default Re: Well I'm gonna install my clutch and flywheel..... (Willard)
i have never dropped a tranny before, but how high do you need the car lifted to do this?
Old Apr 17, 2002 | 07:02 AM
AssPenny's Avatar
Default Re: Well I'm gonna install my clutch and flywheel..... (stRtypR25)
As high as you can get it.
Old Apr 17, 2002 | 07:08 AM
Black R's Avatar
25 Year Member
Most decent floor jacks should get it high enough.....
Old Apr 17, 2002 | 08:44 AM
IN VTEC's Avatar
Posted by AssPenny:
Yo Blacky, I got a clutch alignment tool from when we did my car a few weeks ago. I had it all boxed up for another guy, but he didn't need it. If you want it, it's your's.
Black R - who's my hand-me-down lil' brother
