Here are some wideband graphs from a crome generated ign/fuel map
Old Jun 14, 2006 | 05:37 PM
Sinner's Avatar
Default Here are some wideband graphs from a crome generated ign/fuel map
I had my car wideband tuned with ubderdata for the loggest time. A few months ago I switched over to crome and filled in the parameters for my car and it generated a fuel map. I was amazed when i finally put it on the wideband to how good of a map it really is. I'm not going to change a single cell on the generated map. I'm just amazed at crome right now! My goal is 11:1 AFR since the louisiana summer heat will raise the AFR quite a bit from night to day. I used techedge 2 for logging and some software I wrote to read the csv logs.
Here are some pics
This shows you when i build boost vs rpm, the higher the number the more times data was enter in that cell
So this is a big thumbs up to crome!
Nick
Old Jun 14, 2006 | 06:20 PM
Pullig's Avatar
Default Re: Here are some wideband graphs from a crome generated ign/fuel map (Sinner)
hey whats up what are you using to log this . Im using crome pro right now and i need somthing to graph out my logs like that . Im in Louisiana Also
Old Jun 14, 2006 | 06:23 PM
Sinner's Avatar
what type of wideband do you have? are the logs in CSV? i wrote the software, because I could find any software that did what I wanted.
Old Jun 14, 2006 | 06:26 PM
iBrandon's Avatar
Default Re: (Sinner)
can u make one for plx?
Old Jun 14, 2006 | 06:37 PM
Pullig's Avatar
Default Re: (iBrandon)
im using the innovate LC-1 . I can program the outs to anything i want voltage afr relationship
Old Jun 14, 2006 | 06:41 PM
Sinner's Avatar
are you using a stock honda map sensor?
Old Jun 14, 2006 | 06:43 PM
nowtype's Avatar
What makes this program any different than freelog?
Old Jun 14, 2006 | 06:44 PM
Pullig's Avatar
yeha stock map sensor
Old Jun 14, 2006 | 06:56 PM
Sinner's Avatar
I'll post up a version this weekend. I want to make a few changes. You shouldnt have any problems using it. I think i'm going to be lazy and just make it compatible with honda maps. I wrote this program 2 years ago, but lost interest after I was done tuning my car. I figure the same will happen again.
Nick
Old Jun 14, 2006 | 07:29 PM
iBrandon's Avatar
AEM 5 bar map sensor
Old Jun 15, 2006 | 09:26 AM
Sinner's Avatar
i made the software now where you can use any linear map sensor. But you have to know the specs on the sensor.
Old Jun 15, 2006 | 09:54 AM
nowtype's Avatar
Freelog is already out there. I can see using a piece of software you had and just making a few changes to suit your needs, but freelog is pretty complete at this point. I can't see why anyone wouldn't use it if they needed a free datalogging software compatible with Crome.....
pushinlsteg
May 27, 2005 12:06 AM
Bbasso
Jan 25, 2005 06:09 PM
Pelican
Apr 8, 2004 07:55 AM
