b5 vtec wire... where does it lead on pr3??
im wiring vtec now. pr3 ecu on a mini-me, i plugged A8 with a wire that goes to the solenoid and b5 is supposed to go to the vtec pressure switch, but there is a wire already plugged in that spot, where does it lead so i can just tap into it, i searched but no luck.
thanks in advance
thanks in advance
i think you can cut it , I havent done the vyec wiring in quite awhile, from my recolection I think it is for the eld
ilovemyb16a
May 18, 2006 12:58 PM
