clutch issues, making scraping noise
Ok, I have an ACT heavy duty performance clutch (9ACT-AI2-HDSS) in a remanufactured B series transmission (can't remember what year it is for, but it will be in the range of 90-93, integra). This is all in my 90 civic si with a b18.
At idle, in neutral, when I lift my foot up off the clutch, I hear a scraping noise. It comes from around the transmission area. I put the clutch in, scraping goes away.
I also hear this scraping noise when driving, whenever the clutch is let out. I put the clutch in, and the noise is gone.
What could this be?
What could this be?
that could be. The throwout bearing that came with the clutch was the wrong size (whatever the bearing that goes in the flywheel; i assume thats the throwout bearing unless ive been told wrong), so we replaced it with one from one of the local parts stores (probably CarQuest). It's possible it was an el cheapo or just bad out of the box...That'll be a bitch to change...
When you say input shaft bearing, are you referring to the same bearing by a different name? I guess I can't visualize it...diagrams?
**EDIT: I just found a pretty decent article on it here: http://faq.ef-honda.com/index....ng=en
Still, any other input about this? **
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed--Freak »</TD></TR><TR><TD CLASS="quote">Throw out bearing.</TD></TR></TABLE>
The throw out bearing does not touch the clutch when the pedal is up. It starts spinning when you push the clutch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uberhaulin »</TD></TR><TR><TD CLASS="quote">the bearing that goes into your flywheel should be a pilot bearing.. i would start there or it sounds like it could be throwout bearing..</TD></TR></TABLE>
The pilot bearing spins at the same speed when the clutch is engaged ( pedal up ) when you push the clutch down the trans stops spinning and so does the inner race on the pilot bearing.
my car does the same thing....so you guys think its the input shaft bearing? not just normal chatter? (i got a puck clutch) i thought it only chatters while in gear though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">my car does the same thing....so you guys think its the input shaft bearing? not just normal chatter? (i got a puck clutch) i thought it only chatters while in gear though.</TD></TR></TABLE>
Well a puck clutch is known for that, really depends on the noice.
A scraping/whining noise at idle is not normal .
Stop bragging about your 4 inch puck clutch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">
it isnt really a scraping noise but more of a whine,,,,its not like the whine when you pop it in reverse though,,,its hard to desribe,,but it makes the same whine when you put in 1st and are under 3000revs,,(thats why im thinking its chatter) at idle you can hear it then when you push the clutch in you can hear it slow down and stop,,then the second you let the clutch back up here it is again,,,,,its been running great though for almost 6 months with that same damn noise,,and i put the clutch kit in right....
</TD></TR></TABLE>it isnt really a scraping noise but more of a whine,,,,its not like the whine when you pop it in reverse though,,,its hard to desribe,,but it makes the same whine when you put in 1st and are under 3000revs,,(thats why im thinking its chatter) at idle you can hear it then when you push the clutch in you can hear it slow down and stop,,then the second you let the clutch back up here it is again,,,,,its been running great though for almost 6 months with that same damn noise,,and i put the clutch kit in right....
heres a vid i took tonight,cant see anything but so what..a couple seconds after it starts you can here the whining noise,then you'll hear it stop, then start again.thats from me pushing the clutch then letting it up,,you can clearly hear it,, tell what you guys think...by the way its a 6 puck with stage 2 pressure plate,,been sounding like that since i put it months ago....sorry to threadjack
http://www.yousendit.com/trans...88807
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EF_Si »</TD></TR><TR><TD CLASS="quote">main input shaft bearing, i'm replacing mine tommorow.</TD></TR></TABLE>
ok suppose it is,,what if i just say "F&ck it" and keep driving like this..What can happen? just curious
ok suppose it is,,what if i just say "F&ck it" and keep driving like this..What can happen? just curious</TD></TR></TABLE>
Trans could blow up
, really the input shaft bearing can explode
Trans could blow up
Trans could blow up
, really the input shaft bearing can explode</TD></TR></TABLE>
you listen to that video i posted? just want to make sure it is the input bearing before i take off the tranny again..
Trans could blow up
, really the input shaft bearing can explode</TD></TR></TABLE>you listen to that video i posted? just want to make sure it is the input bearing before i take off the tranny again..
you listen to that video i posted? just want to make sure it is the input bearing before i take off the tranny again..</TD></TR></TABLE>
Just did, defiantly sounds like the input shaft bearing.
OK this is going to be a major pain in the *** and a headache for my 1st time,,,But with my helms i will do it
So Which input shaft bearing and seal do i order for?? its a 90 cable b16 tranny..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">OK this is going to be a pain in the ***,,,But with my helms i will do it
So Which input shaft bearing and seal do i order for?? its a 90 cable b16 tranny..</TD></TR></TABLE>
There is a write up in the eg faq section.
There is a write up in the eg faq section. </TD></TR></TABLE>
yeah i found that one https://honda-tech.com/zerothread?id=596873 and wes's tranny page http://www.performanceforum.co....html
Just wondering what parts do i order for?
black96
29
Jan 3, 2016 08:34 PM
