Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Queston for Kswapped EG circuit goers: mounts and axles
Old Jun 14, 2006 | 11:38 AM
TrackSol's Avatar
Default Queston for Kswapped EG circuit goers: mounts and axles
Pretty simple question. For you guys that are road racing / time attacking, which mounts and axles are you using on your Kswapped EGs?
Hasport or Hybrid-Racing?
Subsiquently, what is your ride height and spring rate?
Thanks
Old Jun 14, 2006 | 11:44 AM
Andrie Hartanto's Avatar
HASport!
Old Jun 14, 2006 | 11:51 AM
Back in Black's Avatar
Rather OG
Default Re: (Andrie Hartanto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrie Hartanto &raquo;</TD></TR><TR><TD CLASS="quote">HASport!</TD></TR></TABLE>
Old Jun 14, 2006 | 12:22 PM
Ekasey's Avatar
Default Re: (Back in Black)
HASport hands down
Old Jun 14, 2006 | 01:46 PM
Todd Reid's Avatar
Default Re: (Ekasey)
Hasport! and driveshaft shop axles!
Old Jun 15, 2006 | 11:14 AM
TrackSol's Avatar
Thanks guys!
I'm going with Hasport then.
As far as axles go, I'm thinking about picking up the circuitworx.com EG 36mm front hubs. This would allow me to use unmodified OEM RSX S/R axles acording to some of the guys on k20a.org.
Are any of you guys runing 98+ ITR 5lug. Which axles are you using? Could you confirm axle length fitment on both sides with OEM RSX axles?
Old Jun 15, 2006 | 11:32 AM
I've been through a lot on the axles. All different length, broke more than a few.
Get the HASPORT axles. Their new axles are not DSS and better. The Stage 1 is as beefy as stage 2 DSS.
The Driver side oem axle is .25" shorter. But it will work. My experience with shorter axle is it will wear out and finally breake the outer joint faster.
The right one is not even close. Just get HASport axles and do it right once.
Old Jun 15, 2006 | 05:36 PM
D.CACO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrie Hartanto &raquo;</TD></TR><TR><TD CLASS="quote">I've been through a lot on the axles. All different length, broke more than a few.
The right one is not even close. Just get HASport axles and do it right once.</TD></TR></TABLE>
Andrie definitely knows what he's talking about on this.....
Old Jun 16, 2006 | 09:11 AM
TrackSol's Avatar
Thanks guys! HAsport combo it is.
Old Jun 16, 2006 | 11:28 AM
chad's Avatar
Moderator
Default Re: (TrackSol)
i have had the DSS for 3000 plus miles and not one failure!!
chad
abs0Lut
Oct 20, 2011 06:54 AM
94ej1b16
Jun 22, 2011 10:03 AM
Lambo123
K Series
13
Oct 1, 2009 11:59 AM
vtec11000
Aug 26, 2004 07:47 AM
redline201
Mar 31, 2004 12:09 PM
