why wont my car start
i have my car at a shop and the guy tells me that the injectors are not fireing right. he said that there is no break in the signal to make them fire. he thinks that it is something to do with the distributor not being the right one or that it isnt wired right. there are no codes so i think that it is wire correctly. so that would sugest that the car has the wrong distributor how can i tell if its the wrong one.
well your fuel rail and distributor do to different things... if your dizzy is putting out spark then thats not the problem so check for spark.. your injectors are controlled by a different module... so just check to see if there is spark
the fuel pump is working but im not sure about the main relay. the injectors get there signal form the cam position sensor that is located in the distributor as far as i know and that is why im worried about the wiring to the distributor. does anyone else have an opinion.
