Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Have issues with Skunk2 Cmaber kit and can't find the solution on the search.
Old Jun 14, 2006 | 08:52 AM
B HATCH's Avatar
Default Have issues with Skunk2 Camber kit and can't find the solution on the search.
Hey,
I think the solution to my problem was posted here, but i can not find it in the search. I have a set of skunk2 arms on our ITR STX car and they are now slipping on the passanger side, this happened after we took the car to the local road course for some fun.
I remember there was a issue with these yet i know come HC cars and others use them with no problems, was there a hardware fix for these? is there somthing i can do or modify on them without reinventing the wheel?
Thanks in advance,
Victor
Modified by B HATCH at 2:55 PM 6/14/2006
Old Jun 14, 2006 | 08:53 AM
ralphie14's Avatar
Default Re: Have issues with Skunk2 Cmaber kit and can't find the solution on the search. (B HATCH)
I think they replaced the supplied hardware with actual 10 grade bolts instead of those allan key deals and also used some Loctite as well That is about all that I can remember.
Old Jun 14, 2006 | 09:04 AM
Jack Black's Avatar
The basic fix is:
1 - Remove the coating from around the slots, where the bolts contact.
2 - Replace the socket head bolts with standard bolts.
3 - Replace the washers used on the bolts with star style lock washers.
Others have gotten more elaborate, but that's the starting point. I personally am stil using the original hardware and have had no problems with slipping. I don't adjust it very often, though, so maybe that helps.
Do an archived topics search for Skunk2. There are tons of threads with useful info.
Old Jun 14, 2006 | 10:05 AM
Todd Reid's Avatar
Default Re: Have issues with Skunk2 Cmaber kit and can't find the solution on the search. (Jack Black)
hi.
i'm using them, too. the secret is to take off ALL the powdercoating where the balljoint/hardware slides.
it took me about 20 mins to carefully remove all the coating. then i roughed it up a bit with a file, both on the top and bottom. i am using the original hardware (with loctite) and it is not slipping.
i roadrace in H1 and last weekend went off-roading at least 5 times. no slippage.
good luck
todd
Old Jun 14, 2006 | 10:45 AM
ryan12321's Avatar
Default Re: Have issues with Skunk2 Cmaber kit and can't find the solution on the search. (Todd Reid)
Here is a product made to fix them. Email Dave. He's a great fabricator.
http://dilysimotorsports.com/P...20Fix
Old Jun 15, 2006 | 12:38 PM
Jeff_B's Avatar
Default Re: Have issues with Skunk2 Cmaber kit and can't find the solution on the search. (ryan12321)
I have the newer version of these arms... I didn't remove the coating, but I replaced the hardware with grade 12.9 allen bolts and locking star washers and haven't had any problems.
Old Jun 15, 2006 | 01:35 PM
mstewar's Avatar
Default Re: Have issues with Skunk2 Cmaber kit and can't find the solution on the search. (ApexSport)
I use the new version with locktite and haven't had an issue.. yet.. <knocks on wood>
Old Jun 16, 2006 | 01:57 PM
j spec's Avatar
Default Re: Have issues with Skunk2 Cmaber kit and can't find the solution on the search. (mstewar)
i haven't had any problem yet but a plan on using loctite and maybe better lock washer as preventative maintenance.
Old Jun 19, 2006 | 06:08 AM
Rene M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jack Black &raquo;</TD></TR><TR><TD CLASS="quote">The basic fix is:
Do an archived topics search for Skunk2. There are tons of threads with useful info.</TD></TR></TABLE>
And buy the bolts just a bit longer and use lock nuts to insure they stay tight. I had this problem for a while my self..
Old Jun 25, 2006 | 10:37 PM
B HATCH's Avatar
Default Re: Have issues with Skunk2 Cmaber kit and can't find the solution on the search. (Rene M)
Thanks to all that posted we solved the problem so far, and have given the car quite a thrashing since we attempted the modifcation and they seems to work great.
Charlie Moua
Suspension & Brakes
May 5, 2009 06:14 PM
shotgun2224
Jan 30, 2008 08:55 PM
tmramsburg
Jun 17, 2007 06:26 AM
nonvtec92
27
Mar 19, 2007 06:49 AM
ensracer
Jun 5, 2004 01:01 AM
