JDM Wheel Bearing and USDM Wheel Bearing Question
Does anyone know if the JDM wheel bearing is the same size and all as the USDM ones? also, is the hub the same? I want to get a 5 lug conversion, but don't want to go with the JDM ones if I can't get important parts like these. Help!!!
JDM 1996 and 1997 are the same as all USDM ITR`s but 1998 - 2001 JDM ITR`s bearings are biger . Also on 98+ JDM ITR the knuckle and the hub is different also because the knuckle accepts the bigger bearing and the hub is bigger where it slides into the bearing.
Sweet. So you guys are saying that as long as I get the '96-'97 JDM conversion, it's the same as the USDM ITR and if the bearing or hub is bad, I can just replace it with the USDM ones?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NsX_CrX »</TD></TR><TR><TD CLASS="quote">Sweet. So you guys are saying that as long as I get the '96-'97 JDM conversion, it's the same as the USDM ITR and if the bearing or hub is bad, I can just replace it with the USDM ones? </TD></TR></TABLE>
You do realize that 96-97 JDM ITR brakes are 4x114.3, right?
94allmotor
Mar 16, 2011 12:47 PM
boostedcivicsir
Jul 2, 2003 01:44 PM
I guess I can't replace any usdm components with the jdm one than, right? Just want to clear that up.
