replacing headlight bulbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">In a DC5? Gotta squeeze your hand in there. Use your fingers.</TD></TR></TABLE>
Exactly. Once you take off the rubber grommets, there's a skinny metal fixture you'll feel. It's hooked on one side and you gotta push around and unhook it. Swing it open like a door and the bulb will be loose.
From: Drop Kicking You In The Head From A Tree, Socal, USA
its pretty much like the 96 and up civics. you gotta remove the grommet and if you have small hands you can push out the pin and get the bulb. just make sure you be very careful and do not touch the bulb!
jfruauff
Oct 25, 2007 02:00 PM
ef_you_again
Apr 10, 2005 12:57 PM
